Help! Can't get ALDL data
He said he gets mostly gibberish, nothing that any of his software packages can decode. He runs a Vette performance shop and seems to know what he's doing, but my car is stumping him.
Anyone got any thoughts?
Thanks!
[RICHR]
http://www.aldlcable.com
Diacom users have reported success logging at 8192 baud. Since Diacom had its own cable and adaptors, it is possible that it was able to connect in diagnostic mode with pins A and B shorted. This is speculation on my part and has not been confirmed.
If you have an auto trans car, an easy work around is to use a newer $32B or $6E bin. Spark advance table may need to be tailored for the 86 iron or 128 heads, if using a newer bin.
I've also rewritten a few $32 bins to correct the serial data initialization, so this is another option, especially suited to 86 4+3 cars. Due to the 86-only differences in the on/off switch wiring, lack of 1st gear switch, and 1st gear detection logic, the later bins won't drop-in and provide correct 4+3 function without modification or re-pinning.
I've uploaded a test bin here: (see post 34)
https://www.corvetteforum.com/forums...post1595584637
My test bin should connect at 8192 baud with 10 k resistor and an appropriate polling message provided by the adx/scan tool.
[RICHR]
EDIT: So these bytes get inserted into the assembly at what address?
I wonder... I used to have an aftermarket Superchips MEMCAL (it was in the car when I bought it) but it (and the original ECU) fried due to wire shrinkage and shorting. I wonder if that chip was corrected from the manufacturer... because it's only been since replacing both that I have been unable to connect properly.
[RICHR]
Its not as simple as inserting a couple bytes. How about some info on the car?
Auto or 4+3? Iron or aluminum heads?
What bin are you currently using? Check the broadcast code on the eprom label.
I'm not sure what bin is currently in the car; I've had several mail order tunes and a stock bin burned to an EEPROM at various times (I used to have a Prominator with 4 of the 8 slots occupied, until that died as well). The guy doing the actual work MAY have started from one of the mail order ones, or he may have started from the stock bin. I'll have to ask him tomorrow.
Thanks.
[RICHR]
-= 86 Coupe 4+3 w/ 91 roller block, LPE 74219 cam, ported SuperRam and base, TRACO headers, PowerEffects catback, DUI distributor/coil, Pro-Topline ported heads (2.02/1.60), forged pistons, Flo-Kooler water pump, RD-Racing CrossBar and harness set, 96 wheels, more. Still being dialed in. =-
