90-93 Steering Columns
Old Feb 17, 2018 | 08:59 PM
LoveThemRoadsters's Avatar
LoveThemRoadsters
Brett Barton
Default 90-93 Steering Columns
I have a 93 automatic car and need to replace the steering column. I have two questions:
1. Will a six speed column fit an automatic car? Automatic cars have a park lockout cable but I think a six speed car would have the equivalent but use reverse instead of park.
2. Will a 94-96 column work in a 90-93? From what I can tell there may be a slight style difference but fitment looks the same.
Old Feb 17, 2018 | 11:51 PM
grantar2's Avatar
grantar2
Why do you need to replace the column? I ask because I just had a guy local to me do a rebuild $300 and it's like new. I used OC Steering columns, realize this is too far for you, but if it's just worn out see if you have a rebuild shop near you. If not you can pull yours there are several shops that will re manufacture it.
Old Feb 18, 2018 | 12:42 PM
LoveThemRoadsters
Brett Barton
Long story not so short.
I was removing the pivot pins to get to the rack assembly because the ignition switch actuator rod came out when I was fixing the park lockout system (cable was sticking).
The pivot pin removal tool broke off inside one of the hardened pivot pins so I drilled out tool and tried to chase the threads in the middle of the pivot pin. The tap broke off and it's as hard as a cobalt drill bit so I can't drill it out.
The only way I think I can get the pin out is to grind away the steering column housing, thus ruining it and possibly the knuckle. The price for these parts alone is over $200. There is also some wear/damage to some plastic parts and the air bag coil (yellow) is a little iffy. The steering wheel could stand some refreshing too.
I've found some complete six speed columns and 94-96 columns that are cheaper than the 90-93 columns so I figured I could save a lot of hassle by replacing the entire column and could part out the old column to help cover the costs.
Old Feb 18, 2018 | 02:12 PM
WVZR-1's Avatar
WVZR-1
If you relieve the 'tension' of the compression spring that provides tilt effort the pin removal should be much easier and I'd think not an issue. For you I'd say the purchase of a column is time & $$$$ wasted.
If you had no tilt issues you get just another pin. If you had issues maybe you buy one of the over-sized in an effort to correct the tilt.
Do you have a FSM for the car?
See page 36 & 37 in this document for the spring that I mean. It sounds as if you could have used this when you started. There's no good reason for the damage you now have. All 'self inflicted'! I likely have all of the parts you need - I should have a correct column also.
http://www.crankshaftcoalition.com/w...ck_Rebuild.pdf
Old Feb 18, 2018 | 04:53 PM
grantar2's Avatar
grantar2
That sucks, however check your area and see if you have a rebuilder who is also mobile. Since they are experts they have likely been there seen that, and could help.
Old May 14, 2018 | 12:30 PM
boris#one's Avatar
boris#one
2nd Gear
I have c-4 1991 and the actuator plastic came off the dimmer switch rod when I was adjustining cover but got stuck in geer ing switch could not turn key removeed plastic part key now turns but won't start
Old May 14, 2018 | 12:35 PM
boris#one's Avatar
boris#one
2nd Gear
[QUOTE=boris#one;1597196554]I have c-4 1991 and the actuator plastic came off the dimmer switch rod when I was adjustining cover but got stuck in geering switch could not turn key do i need to remove steering wheel? to put part back on and how does it fit
Old May 14, 2018 | 05:17 PM
DUB's Avatar
DUB
Not saying that it could not happen to me...I have been lucky and not had my pivot pin remover tool break.
The tilt spring is under so much tension like previously mentioned...it MUST be removed.
I know I could get the pin out if I had to...and not buy a column.
DUB
To 90-93 Steering Columns
