USB Charger
Old Feb 18, 2018 | 08:39 PM
Hammerhead69's Avatar
Hammerhead69
Default USB Charger
Has anyone installed a usb charger in their C4? Not the cig. lighter plug in type but a permanent mount.
Something like this?
Old Feb 18, 2018 | 10:39 PM
Benben's Avatar
Benben
8th Gear
They aren't difficult if you've done wiring work before. What's your specific issue?
Old Feb 19, 2018 | 12:27 PM
Hammerhead69
I’d just like to install a permanent usb charger that doesn’t look too out of place. I was wondering if there’s a power scourge to tap into.
Old Feb 19, 2018 | 12:43 PM
drivestwin's Avatar
drivestwin
I don't know what year you have, but the later c4's have 3 wires just for the purpose of addition something like this. They are tucked away in the center console, just waiting for you to use them.
Old Feb 19, 2018 | 12:44 PM
Bfenty's Avatar
Bfenty
2017 C4 of Year Finalist
you could replace the cig lighter with that one probably. Just pop the cig lighter out and insert that one, then wire to the cig lighter wires.
If you want to add it someplace else, you can put one into the center console under the lid and just run the wires off the cig lighter or radio power. Someone else can tell us if the cigarette lighter is always on or if it's just on when the key is on.
Old Feb 19, 2018 | 04:27 PM
Hammerhead69
Thanks for the replies. It’s an ‘89 so it has the older style center console. I don’t really want to install one where the cig lighter is because I don’t want to leave the lid open when something’s plugged in.
Old Feb 19, 2018 | 04:39 PM
Bfenty's Avatar
Bfenty
Then I'd put it in the center console. You'll have to take the lid off and the shifter surround, run the cable past the shifter and drill a hole into the compartment in the middle to mount your outlet.
I did the same thing, but ran it from the back USB on my stereo so that I could put my phone in the center console and lock it and still have it plugged into the radio for playback.
Usually those USB mounts are 3/4", can get a paddle bit from Lowes pretty cheap. Put some painter's tape over the plastic to protect it and make it easier for the drill bit to bite.
Old Feb 19, 2018 | 09:17 PM
Hammerhead69
Thanks!
To USB Charger
