Window regulator lube question?
Old Oct 14, 2002 | 06:59 PM
kenfusion's Avatar
kenfusion
Default Window regulator lube question?
What type of lube do you use on the window regulator ribbon? I've replaced my driver's side ribbon twice in one year now and I am wondering what caused the part to bad so fast. :mad
Ken
Old Oct 15, 2002 | 01:53 AM
drive it's Avatar
drive it
Default Re: Window regulator lube question? (kenfusion)
GM upgraded that ribbon design in 86 to 87 to a metal arm design because of the ribbon failing. You can upgrade yours-not cheap and takes some time, but I did it after replacing too many ribbons....
Old Oct 15, 2002 | 02:36 AM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: Window regulator lube question? (drive it)
try some good synthetic grease or lithiuim grease either should work fine my major complaint with the older windows is that they are so dam slow going up :cheers:
Old Oct 15, 2002 | 02:49 AM
JonM's Avatar
JonM
If anything, I would use graphite powder....its not like greese so dirt doesn't stick to it.
Old Oct 15, 2002 | 02:53 AM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In V Veteran
Default Re: Window regulator lube question? (JonM)
yes but will it stick to the ribbon :cheers:
Old Oct 15, 2002 | 03:21 AM
JonM's Avatar
JonM
Default Re: Window regulator lube question? (CORKVETTE1)
Yes it will...its finer then talc...that stuff sticks everywhere
Old Oct 15, 2002 | 03:46 AM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In V Veteran
hmm :cheers:
Old Oct 15, 2002 | 11:30 AM
vettmech's Avatar
vettmech
I didn't put ANYTHING on my ribbon........I greased the track though...... :seeya
To Window regulator lube question?
