1984 egr delete question
Old Mar 7, 2018 | 01:56 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Originally Posted by 84 4+3
Got you. It makes sense since it's vacuum operated and electronically controlled. If I were to lightly press up on the egr diaphragm at idle it surges. That takes very, very little force. Much more than when it is off. Guess that means I have something else to add to the list.
It sounds like vacuum is "leaking" through your control solenoid. If you had full manifold vacuum, the egr would be OPEN...car would likely stall. Since the diaphragm moves up with such little effort, it's as if you have a partial vacuum pulling on the diaphragm, when at idle, there should be none.
Old Mar 7, 2018 | 04:21 PM
gnj3963's Avatar
gnj3963
Originally Posted by corvettenorway
blocked off mine 5 years ago , no problem , the same engine temp. no pinging
Its funny.ive read so many posts saying not to delete the EGR because of negative reasons..But have not seen one post of anything bad actually happening.
Old Mar 7, 2018 | 04:35 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
People like to worry about **** that don't need worryin' about....sometimes.
Old Mar 7, 2018 | 04:47 PM
gnj3963's Avatar
gnj3963
very true...I see your a ski guy..im in new jersey..we r in middle of snow storm right now..We are in state of emergency as i type this..
Old Mar 7, 2018 | 05:20 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Get a buddy. Tie a waterski rope to the hitch of your 4x4. Go have a blast!
Yep I've been skiing all my life. Used to ski at Mt Wachusett when I was a kid!
Now I work at Snowbird. What a change.
Old Mar 7, 2018 | 05:26 PM
gnj3963's Avatar
gnj3963
yep..i drag my 7 year old from the back of my quad..
Old Mar 7, 2018 | 06:42 PM
zachaeous's Avatar
zachaeous
Blocked mine off when I replaced my engine in 2014. Have noticed no ill effects at all. Also removed air pump and cat. Went with the shorter belt as well to work without the air pump.
Old Mar 7, 2018 | 10:02 PM
1984Z51auto's Avatar
1984Z51auto
On my 1984 I ported the Cross-Fire intake, removed the EGR "dong" from the plenum, installed a commercial egr block off plate and went with later Corvette aluminum heads and a commercial computer chip upgrade (Hyper-chip I think). I ran it hard for years with absolutely no ill effects. My compression would have been higher than stock due to the smaller chambers on the aluminum heads vs stock iron. I did use premium gas. You should be just fine.
Old Mar 8, 2018 | 08:29 AM
gnj3963's Avatar
gnj3963
hey, thanx for all the replies..I bought this car about 7 months ago.It was totaly neglected..I have been rebuilding evey system in the car..
all sensors changed
fuel pump (1985)
rebuilt transmission for barret transmissions
master cylinder
brake lines
IAC,s
tires
4 wheel alignment
bushings
shocks
power steering lines
ac eliminator pulley
serpintine belt
full tune up
and the list goes on and on..
working on moldings and door pins now.....ughhhhh
