small clunk
Old Oct 15, 2002 | 09:52 AM
GlockLT4's Avatar
GlockLT4
Default small clunk
I have a small clunk anytime i'm in gear at a moderate rpm's and i blip the throttle ... U-joint? I don't think i've heard the same noise from other manual tranny vettes. Would that be covered under my warranty ? :)
[Modified by GlockLT4, 7:53 AM 10/15/2002]
Old Oct 15, 2002 | 10:20 AM
ittlfly's Avatar
ittlfly
Default Re: small clunk (GlockLT4)
If a slight acceleration or decrease in speed causes a clunk, then it sounds like slop in a u-joint(s). Put the car up on jack stands (safely) and you can check it by hand underneath.
[Modified by ittlfly, 6:21 AM 10/15/2002]
Old Oct 15, 2002 | 10:22 AM
GlockLT4's Avatar
GlockLT4
Default Re: small clunk (ittlfly)
yup... but if it's covered by warranty, then I'll just take it in.
Old Oct 15, 2002 | 10:27 AM
ittlfly's Avatar
ittlfly
:cheers:
Old Oct 15, 2002 | 06:45 PM
VetBoy89's Avatar
VetBoy89
It depends on the warranty that you have. My u-joints weren't covered by mine. It should say exactly what's covered in your warranty paperwork. If not, just call them and ask 'em. :cheers:
Old Oct 15, 2002 | 07:17 PM
hngacurv's Avatar
hngacurv
Default Re: small clunk (VetBoy89)
nevermind. just found my answer in another thread about u joints.
[Modified by castivers, 11:18 PM 10/15/2002]
Old Oct 15, 2002 | 08:10 PM
GlockLT4's Avatar
GlockLT4
Default Re: small clunk (castivers)
yeah .. drive shaft are easy... half shafts aren't so easy.
BTW, i'm pretty sure that I do have a U-joint out because i have a vibration at 75mph that I thought was related to a wheel out of balance, but if it's making a small clunk AND it's got a vibration, that sounds like the culprit. :yesnod:
To small clunk
