1987 basket
Old Apr 26, 2018 | 03:14 PM
N2NITRO's Avatar
N2NITRO
4th Gear
Default 1987 basket
my daughter-in law just dumped 1987 corvette in my lap.Where can I find a good manual to show a routing of vacuum lines? Also is there a place that sells both hard and soft vacuum line complete kits or some parts for intake and injector?
Old Apr 26, 2018 | 03:34 PM
zachaeous's Avatar
zachaeous
The factory service manuals are your best bet. Ebay has them for sale most of the time and sometimes here on the forum in the C4 parts for sale section.
I do not know of any vendor who sells a vacuum line kit.
Good luck getting you car fixed.
Welcome to the forum.
Old Apr 26, 2018 | 04:44 PM
N2NITRO's Avatar
N2NITRO
4th Gear
Thank you for your quick response I will pursue these options
Old Apr 26, 2018 | 10:02 PM
jv9999's Avatar
jv9999
Someone posted a pdf download of the '87 service manuals here a couple times. I'd try a search.
Old Apr 27, 2018 | 01:05 AM
N2NITRO's Avatar
N2NITRO
4th Gear
I do a search on this site any pointers thanks in advance
Old Apr 27, 2018 | 08:43 AM
JimLentz's Avatar
JimLentz
The search within the site is not good, but using Google I found this.
Old Apr 27, 2018 | 09:13 AM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Welcome to the forum, Grats on your project. In no time you'll driving. Lots of very knowledgeable C4 guys here.
You may want to post your area maybe someone in that area will be willing to help.
Old Apr 27, 2018 | 09:35 AM
fredk's Avatar
fredk
I was looking for the vacuum line kit as well. Can't find anyone who sells it.
Old Apr 27, 2018 | 09:41 AM
FASTAZU's Avatar
FASTAZU
St. Jude Donor '16
You may have to buy the soft lines and rebuild it a piece at a time.
Old Apr 27, 2018 | 12:45 PM
c4cruiser's Avatar
c4cruiser
The chain auto parts stores will have lengths of rubber vacuum line in various diameters as well as flexible plastic (hard) lines. The "HELP" brand of these items should be enough to get you started on line replacement. HELP also has a variety of vacuum line fittings that will probably be needed for the rebuild.
For a "good manual" you need to get the Factory Service Manual (FSM) set for your year of Corvette. These will usually show up from time to time in the C4 Parts For Sale section of the forum and they can also be found on eBay. These year-specific books are the same ones that were used by the service techs at Chevy dealerships.
Old Apr 27, 2018 | 02:14 PM
Dt86's Avatar
Dt86
You must really like your daughter in law...
Just buy the lines locally and replace every single one of them. If you don't you'll be back again doing the same thing. They get hard and brittle after 30 years of heat cycles. The egr vacuum lines run under the plenum, are you pulling it?
Old Apr 27, 2018 | 04:26 PM
N2NITRO's Avatar
N2NITRO
4th Gear
Basket yes I'm going to change everything from the e g r valve up all hardlines and softlines what PDF should I download for a 87 that'll give me all the ports and locations for all the lines
Old Apr 27, 2018 | 05:48 PM
playsdixie's Avatar
playsdixie
welcome....lots of good help here. Get a fsm from ebay...you'll be needing a hard copy for the pictures....greats cars but, you'll know all about it before it's over.....seeing the state you're in, you'll be needing to keep it stock......good luck
Old Apr 30, 2018 | 12:55 PM
xrav22's Avatar
xrav22
One at a time, do not trust your memory!
Old May 1, 2018 | 10:28 AM
kael's Avatar
kael
Finalist 2020 C4 of the Year - Unmodified
The hard part is finding new tubing that's not the huge, hideous stuff.
I finally found Dorman tubing that works, check the size. The flexibility of this stuff does point to how brittle the old tubing has become.
https://www.dormanproducts.com/c-56-hose-tubing.aspx
Oreilly had this in their "emissions" area.
To 1987 basket
