New Cam
Old May 13, 2018 | 09:23 AM
Kim Hil's Avatar
Kim Hil
Cruising
Default New Cam
I'm having a Comp Cam Extreme 266hr-14 cam installed in my 95-C4.
Is there anyone that has experience with the performance of this cam?
Does it have a good sound?
Old May 13, 2018 | 03:03 PM
84 4+3's Avatar
84 4+3
I wouldn't add a cam just for sound. However you're adding about 6 degrees of duration. It should sound somewhere between stock and the lt4 hot cam if I had to guess... Should run well.
Old May 14, 2018 | 12:33 PM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
I hope that you are replacing the springs at the same time.
While you are in there; replacing the stamped factory rockers with roller rockers will bring back some of the HP that is absorbed by the friction of the non-roller oem rockers.
Old May 14, 2018 | 01:18 PM
whalepirot's Avatar
whalepirot
Originally Posted by Mr. Peabody
replacing the stamped factory rockers with roller rockers.
Not changing lifters might void the cam warranty.
Old May 14, 2018 | 06:20 PM
Kim Hil's Avatar
Kim Hil
Cruising
Default new cam
You are correct. I bought the kit. Cam, lifters, springs, rockers.
Thanks for the input.
Old May 17, 2018 | 03:14 PM
64Scout's Avatar
64Scout
[Url]
Old May 17, 2018 | 08:18 PM
jayjones's Avatar
jayjones
Originally Posted by 64Scout
TL;DR tested several different rockers incl roller and ball. The only hp difference found was probably due to ratio (1.5 vs 1.6). Many factors have to be considered such as float resistance etc, but in the test none of it seemed to make a difference.
Old May 18, 2018 | 06:27 PM
Mr. Peabody
Thank you! That was very interesting.
Yes I was surprised as I had always been under the impression that friction within the valve train components robbed available HP and that full rollers would significantly help that situation.
That's why I love this forum..... learn new things every day.
To New Cam
