Slight Optispark issues?
Old May 17, 2018 | 01:34 AM
jsgun's Avatar
jsgun
Default Slight Optispark issues?
I can't figure this out. I have a 92 LT1 automatic with 59k miles. I have a mode 4, H36 code. Searching and lots of reading says this is typically an Optispark failing. But i'm not getting the typical optispark type symptoms.
The problems are very mild. Starting the car, it takes 3 or 4 seconds, where it was previously almost instant. Once running, the engine fans are at 100%. Slow, very slight throttle (like parking lot cruising) is somewhat rough running. Once moving it's lower on power. I'd guess about 300-500 rpm more to get to speed than usual. I'm guessing at around 2k rpm (my tach has been dead for a while now), at a steady speed, there's a very slight miss. Letting off the gas, there's a lot more drag than normal. It's stalled out at a stop light, and while parking, but only 3 times. Sometimes the idle is really low when in gear, and on the brake, but it seems smooth. I've noticed that the average MPG has gone from 14.7, to 15.2. Lean condition?
I'm not getting lurching, or backfires, or anything dramatic. Just trying to figure out what it could be, before I start replacing parts.
Old May 17, 2018 | 06:04 AM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Before you jump into "Opti Land" put a real pressure tester on your fuel rail and double check you are getting all that you need.
Your situation sounds a lot like lack of fuel pressure.
BTW... don't throw parts at this. Do some diagnostics first. Save your money and fix your tach.
Old May 17, 2018 | 04:15 PM
dizwiz24's Avatar
dizwiz24
this is a time i will agree that it sounds fuel related..... (and not optispark).
weird that fan comeson 100% - something putting ecm it into a limp home mode ?
Old May 17, 2018 | 08:40 PM
fake's Avatar
fake
Change the fuel filter. Read the FM and this site for your safety
Old May 17, 2018 | 09:10 PM
jsgun's Avatar
jsgun
It seems to be degrading, getting worse just a little at a time.
Would low fuel pressure register as an error code, or is it not monitored like that? When I floor it, it still takes off well. Just a little higher RPM. Previous experience with carbs and mechanical fuels pumps seemed to act the opposite. Fine at low speed, and dying when punched down.
Could the H36 error be a symptom of something else, and not an indication of a cause (the optispark)?
Also, is it worth finding someone with a OBD1 reader to check codes? Would that show more info than just H36?
Old May 18, 2018 | 01:00 PM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
Highlighting is mine. Based on these particular observations I think that you may experiencing issues with the auto trans.
I know that some of what you mentioned go against that premise such as your improved MPG ... but none of what you are describing says optispark to me.
Old May 18, 2018 | 07:47 PM
dizwiz24's Avatar
dizwiz24
What about fuel filter ?
Old May 19, 2018 | 10:40 PM
jsgun's Avatar
jsgun
I don't have a means to test fuel pressure, so i'll have to find a shop that can do it. All my tools are for dealing with carbs. I don't feel that it's fuel because it comes in strong at higher throttle. But it would be good to test the pressure.
I've been reading about obd1 and optispark, and it's starting to seem like it's in a partial limp home mode. It's my understanding that limp home is very rough running, and i'm not really experiencing that. I've read that the computer locks the advance, and it does feel like that. Years ago I had a old ford that had the mechanical advance seize up. It runs very much like that. Crappy at low RPM, and fine at higher, except I start to get a random miss. Advance is in the computer, so could it be the ECM? Something is causing that H36 error.
Old May 20, 2018 | 09:40 AM
1stVetteFinally's Avatar
1stVetteFinally
testing fuel pressure is easy and a fuel pressure gauge is not expensive. https://www.harborfreight.com/fuel-i...ter-62623.html
Old May 30, 2018 | 08:25 PM
jsgun's Avatar
jsgun
I suspect it's a wiring issue. Saw a video on youtube of a guy having a H16 low resolution opti error, and after 2 distributors figured out it was the ground wire from the bellhousing to frame.I replaced mine this weekend, and saw a partial improvement. Engine runs at full power much more often, but not always. The hard cranking, fans always on high, and error light are staying. Replacing other grounds as i'm able.
Old Jun 9, 2018 | 10:37 AM
64Scout's Avatar
64Scout
I agree, but I think there's an issue with the torque converter not locking and unlocking correctly.
To Slight Optispark issues?
