Power window switches
Old Oct 18, 2002 | 02:28 PM
Greg Johnson's Avatar
Greg Johnson
Default Power window switches
Anybody have trouble with intermittent window switches?
Greg
Old Oct 18, 2002 | 02:36 PM
Steel Blue 91's Avatar
Steel Blue 91
Default Re: Power window switches (Greg Johnson)
My PS window switch goes down fine put won't go up (from time to time) using the PS switch. Need to go in and check the connections. Maybe this weekend.
Old Oct 18, 2002 | 02:52 PM
Phil-tha-Rush's Avatar
Phil-tha-Rush
Default Re: Power window switches (Steel Blue 91)
when I had that same (?) problem 2 years ago, it turned out it was my motor gone bad.
when you say "go down, but wont go up", do you me will go all the way down, then wont come back up?
if so, I quareentee its a motor gone bad. (dead spot on the aparture)
Old Oct 18, 2002 | 03:05 PM
Steel Blue 91
Default Re: Power window switches (Phil-tha-Rush)
What I meant was that the PS switch won't move the window up at all. I have to use the DS switch. If I lean over and push in on the PS switch and push it up, the window goes up fine. I'm thinking coroded connection or a switch on the way out.
Old Oct 18, 2002 | 03:26 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I had to replace the passenger side window sw, and on a slightly rainy day. :eek:
Old Oct 18, 2002 | 03:28 PM
Steel Blue 91
Default Re: Power window switches (65Z01)
But of course. Things like that don't fail on a nice sunny and warm day :nonod:
To Power window switches
