Vacuume hoses
Old May 24, 2018 | 04:43 PM
robertm1958's Avatar
robertm1958
8th Gear
Default Vacuume hoses
Hello Everyone,
I want to change all of my vacuume lines on my 1994 base coupe since they are cracked and need to be replaced. Trouble is, I don't know the correct hose diameter's or where to get them. I've tried Corvette Central and Ecklers. No help. Can someone please help me? Thank You!
Old May 25, 2018 | 07:10 AM
Joe C's Avatar
Joe C
a couple years ago, I replace everything on my 85. only a few sizes are used. most was 5/32" and as I recall, there were only couple different sizes - (i'm thinking) 1/4, 7/32, and maybe 5/16 and 3/8 - ??? I bought a 50 ft, bulk roll of the 5/32" and probably used about half the roll. IIRC, gates brand and bought it through amazon,
Amazon Amazon
. other sizes, in 10 ft rolls, some local, some on-line. while your at it, replace the windshield fluid lines, cruise, and vacuum lines for the fuel line emissions. the emissions lines require lines compatible with gas and oil. I do remember getting the emission line stuff at NAPA. can't recall what's needed on an LT1 car, but my 85 used some plastic tubing assemblies. I was able to replace my patch-work pieces with good used, and NOS. pull some of your original hoses and size-match for your needs.
Old May 25, 2018 | 10:24 AM
belairbrian's Avatar
belairbrian
Since were talking vacuum hoses, I'll pile on with another question.
I know the HVAC control vacuum hose uses a bulkhead fitting on the firewall so the hose itself doesn't actually go though. Does the hose from the cruise to the brake switch have the same setup or does the hose go all the way through.
That one hose is turning to dust on my 92 Auto.
Old May 25, 2018 | 11:03 AM
WVZR-1's Avatar
WVZR-1
This on most years was a 'hose & grommet' - I'm quite sure it was actually a part #'d affair (GM # 14091289). In your FSM it's very well illustrated and mentions even APPLYING LUBRICANT AT THE GROMMET.
In your FSM look at or near 9B-3. I had a '93 FSM open at the time and didn't check a '92.
Old May 27, 2018 | 05:52 PM
DUB's Avatar
DUB
I hate to disagree with you but the plastic vacuum tubing that is in clump of wires that are in the bulkhead connector that is bolted to the firewall...is a continuous tube that goes through the firewall.
Unless I am having a total brain fart. That bulkhead connector that is behind the right valve cover area is not a point where the wiring harness separates. But rather it is only a point where GM bolts the harness to the firewall and seals it off from the interior.
As mentioned..the hose runs through the firewall so it is a continuous hose from the cruise servo to the brake pedal switch.
And YES..I have replaced many and I use silicone grease and it is still FUN to get it to go through the firewall mat and all that.
DUB
To Vacuume hoses
