Power window Issue
Old May 25, 2018 | 09:24 AM
roger43's Avatar
roger43
4th Gear
Default Power window Issue
I have a 1994 LT1. Both power windows operate properly from the driver side. The passenger side switch does not work the passenger window. Any suggestions?
Old May 25, 2018 | 10:30 AM
TheBlaster9001's Avatar
TheBlaster9001
I'd check out the passenger side switch first. Pull the door panel, check that the switch actually closes a circuit by using the 'continuity test' on a multimeter. I suspect the switch is shot, I had one go intermittent then fail, was 9 bucks for a new one.
Old May 27, 2018 | 05:41 PM
DUB's Avatar
DUB
On a 1994 the power window switch as to be removed in order to take the door panel off.
In some instances the wiring harness connectors can also be pulled through the hole in the door panel where the swithc is installed...so all testing can be done and the door panel does not need to be removed. But it still may required for it to be removed.
The switch for this car is a lot more than $9.
Not being there to preform tests..I would be it is in the switch but like I just wrote...I have no clue if something is not right causing it to not work off that switch.
DUB
To Power window Issue
