What Grease for Poly Bushings?
Old Jun 8, 2018 | 06:49 PM
81c3's Avatar
81c3
Default What Grease for Poly Bushings?
I bought some VBP poly bushings from a member and I think Ill need the grease... what is it called and where can I get it?
TIA
Old Jun 8, 2018 | 07:43 PM
Pwnage1337's Avatar
Pwnage1337
I got a small tub (8 oz??) From energy suspension, through Summit. It's extremely tacky and I recommend wearing latex gloves because that **** sticks to EVERYTHING.
Old Jun 8, 2018 | 09:05 PM
PatternDayTrader's Avatar
PatternDayTrader
I would use a silicone base product on poly.
Old Jun 8, 2018 | 09:45 PM
Joe C's Avatar
Joe C
I have several old jars of dow-corning #11 silicone grease. it's been discontinued, but fairly sure it's been replaced with #111. I've been using #11 since the 70's on just about everything needing a silicone lubricant. I greased the hell out of my poly bushings, wiping the excess. to date, no issues, no squeaking.
Old Jun 9, 2018 | 02:08 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
That's what I always use on poly bushings.
Old Jun 9, 2018 | 08:59 PM
zachaeous's Avatar
zachaeous
I just finished my 84 two weeks ago and used almost the whole little tub. I also used latex gloves to handle the grease. It was very hard to get off of any thing it touched.
Old Jun 12, 2018 | 03:51 PM
81c3's Avatar
81c3
Found a 8oz tub at Kragens $12. Energy Suspension labeled .
Old Jun 13, 2018 | 08:20 AM
81c3's Avatar
81c3
Quick question.... when assembling the poly bushings, the bore of the part is not lubed, nor is the outer portion of the bushing correct?
Old Jun 14, 2018 | 04:58 PM
jmgtp's Avatar
jmgtp
Grease the insides bore of the bushings where the steel sleeves fit. Be generous and wipe the excess off the surface after pressing the sleeves in. Those who have recommended gloves are on point. The grease is very tacky.
I've rebuilt my entire suspension, rear about 4 years ago and front 1.5 years. I used the energy suspension black kit, whit has graphiteninpregnated bushings. No squeaks heard to date.
Old Jun 15, 2018 | 02:50 AM
cv67's Avatar
cv67
St. Jude Donor '05
Went the polygraphite ones also, no squeaks at all.
The original poly bushings squeaked bad not sure about todays, some did some didnt. Used some blue Kendall bearing grease to be safe.
They sure do ride nice, car feels more positive..nothing like the feel of a fresh suspension rebuild.
Old Feb 2, 2026 | 06:42 PM
zim64's Avatar
zim64
Wrong forum
Old Feb 8, 2026 | 10:42 PM
Nexxussian's Avatar
Nexxussian
I tend to use a product called Sil-Glide.
I've bought it at NAPA.
I grease every surface of the polyurethane.
Old Feb 9, 2026 | 09:51 AM
standswithabeer's Avatar
standswithabeer
from an email, VBP recommends Teflon and silicone based grease from Energy Suspension.
Old Feb 9, 2026 | 01:28 PM
AZSP33D's Avatar
AZSP33D
Standard poly bushings are not really suitable for rotating bearing suspension points, they are grabby, cold flow and deform in a short time period, are influenced by temperature, and shed any lubricant in a short amount of time, and tear if installed very tight. The OEM rubber bushings that work in shear instead of rotation are much superior, Delrin bushings are even better for rotation in a single axis (upper and lower control arms in an SLA) and high quality rod-end style bushings if there's three dimensional movement/rotation (rear lateral links for an IRS or 3/4 link solid axle). The places where they may be acceptable would be the rear diff mount, leaf spring mounts, perhaps the large sway bar mounts but that's iffy. Copper anti seize seems to last longer in these areas, less dirt attracted, doesn't degrade Poly like petroleum lubricants mentioned, isn't a grit magnet like the silicone greases.
To What Grease for Poly Bushings?
