Z51 vs. Z07
Old Oct 19, 2002 | 08:50 PM
Chief Muktar's Avatar
Chief Muktar
Default Z51 vs. Z07
I was wondering if anybody knew of any differences between a 1990 with Z51/Z07 and a 1991 with Z07/FX3? Does either one come with extra options that the other doesn't?
On this chart http://www.vettenet.org/susp_chart.html the Z51 shocks are rated @ 4 the Z07 shocks are a 5. What does that mean, that the Z07 are slightly stiffer? the corvette challenge options also has itentical specs to the Z07, does that mean that both cars will perform simularily or is there a lot more to the corvette challenge option? Anybody know?
Old Oct 19, 2002 | 09:17 PM
silver & red CE's Avatar
silver & red CE
Default Re: Z51 vs. Z07 (Chief Muktar)
...the Z51 shocks are rated @ 4 the Z07 shocks are a 5. What does that mean, that the Z07 are slightly stiffer...?
If you scroll to the bottom of the chart you'll see:
4-Delco/Bilstein gas shock, Z51 specfic
5-Ride-adaptive Delco/Bilstein gas shock
Eric
Old Oct 21, 2002 | 03:41 PM
Chief Muktar
Default Re: Z51 vs. Z07 (silver & red CE)
:bb oops I didn't see that, thanks :cheers: Whats different about the ride adaptive shocks? Doesn't that FX3 option give me speed adaptive valving? Or is that totally different :confused:
Old Oct 25, 2002 | 02:32 PM
Chief Muktar
ttt
Old Oct 25, 2002 | 03:25 PM
Silver89's Avatar
Silver89
The FX-3's in the Z51 are just like most adjustable shocks... they adjust by turning the **** and that's it. The Adaptive ones adapt on-the-fly according to their set parameters and inputs.
[Modified by Silver89, 12:25 PM 10/25/2002]
Old Oct 28, 2002 | 08:55 AM
bhamvett's Avatar
bhamvett
Default Re: Z51 vs. Z07 (Silver89)
Very interesting.
bhamvett
Old Oct 28, 2002 | 09:14 AM
96GS#007's Avatar
96GS#007
:nono:
Z07 was available from 1991-1995. Z07 combined RPO Z51 with RPO FX3, including the stiffer Z51 springs.
In 1990 if you ordered Z51 & FX3 together, you got all the Z51 components *except* the Z51 springs. Other Z51 components in 1990 included the 13" brakes, engine oil cooler, etc.
In 1996, Z07 was no more, replaced by Z51. FX3 was replaced by F45 Real Time Damping (RTD). F45 & Z51 could not be combined.
:cheers:
Jim Mason
'96 Grand Sport #007; former 1990 Z51 ZF 6 owner
Old Oct 28, 2002 | 02:32 PM
Chief Muktar
Default Re: Z51 vs. Z07 (96GS#007)
Ok, so then by just installing a Z51 rear spring into my car I probably mucked up it's handling? I can't tell because It's off the road now, but I assume that having a stiffer rear spring will cause my car to handle funny, with over/understeer right? oops...
Old Oct 28, 2002 | 03:04 PM
96GS#007's Avatar
96GS#007
You need to install both the front and rear springs or, as you state, you'll have some "funny" handling characteristics.
Jim Mason
To Z51 vs. Z07
