KBD targa mufflers
Old Jun 11, 2018 | 11:09 PM
85 CRVET's Avatar
85 CRVET
Default KBD targa mufflers
Hi, I am planning on upgrading the exhaust on my 1985 corvette soon and am getting the kbd targa mufflers. I was wondering if there is a difference between the 2 1/2” mufflers or 3” or if it is just the tips? If it is just the tip I would get the 2 1/2”. I am getting a 3” true dual exhaust all the way back to these mufflers with a crossover.
Old Jun 11, 2018 | 11:15 PM
Pwnage1337's Avatar
Pwnage1337
If you are getting 3" all the way back, I would verify with the seller that the inlet for the KBD targa mufflers is 3."
Instead of a crossover on the rear Y-pipe, I'd go for an X pipe mid stream, closer to the headers/exhaust manifolds if you can swing it.
Old Jun 12, 2018 | 01:12 PM
85 CRVET's Avatar
85 CRVET
From what i have seen both sizes in tips just change the tip and the inlet is 2 1/4” on both of them. I thought the exhaust shop would be able to use a reducer to change it to this size right before the mufflers. Or am I wrong and this would hurt the performance? If it would hurt performance I would just have to find some different mufflers but I really liked the looks of them and people said they make it sound like a 70’s muscle car plus it is like a straight pipe but it’s really a glass packed muffler inside.
Old Jun 12, 2018 | 01:13 PM
85 CRVET's Avatar
85 CRVET
And I will tell them to do the x pipe right after the pipes come close to each other in the middle of this should work better.
Old Jun 12, 2018 | 01:59 PM
85 CRVET's Avatar
85 CRVET
The inlet may be 2 1/2”. Would this be big enough to not hurt the performance of a 3” true dual?
Old Jun 12, 2018 | 02:30 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Theoretically yes, but in practice not really.
You don't say much about (any) performance mods to your car, so 2.5 will be plenty. Plus, you will only feel a difference (if any) at the far upper RPM bands.
For everyday cruising, 2.5 will be a clean install, sound great and give you a bit of a kick. Remember to get rid of your cat and put in a hi-flow catalytic. THAT will make a difference.
Old Jun 12, 2018 | 02:56 PM
85 CRVET's Avatar
85 CRVET
Vader86 told me how to get up to 300 hp from the engine with 3” true dual, long tube headers which I will get later. Then port the plenum and runners and a new intake manifold. That’s why I want to get 3 inch true dual and was wondering if it would hurt the performance at all if the muffler inlets are only 2 1/2”?
To KBD targa mufflers
