ZF six speed problem
Old Jun 29, 2018 | 03:24 PM
  #41
TheGreek!'s Avatar
TheGreek!
Originally Posted by 856SPEED
BTW;
another option is to move the idle speed up until the noise is minimal....that’s where mine was annoying...w/o the clutch engaged.
I moved my idle speed up to 1,000 RPM which nearly eliminated the “ rocks in a can” sound w/o the clutch engaged...Now, I run a Holley HP ECM making that adjustment much easier.... but with my cam, the idle is smooth...just not as lumpy like it used to be...
The noise at idle is annoying but it isn't anywhere near as bad as it is when accelerating in all six gears. I wish it was only noisy at idle, I could live with that.
Old Jun 29, 2018 | 04:19 PM
  #42
856SPEED's Avatar
856SPEED
interesting....well, I am speculating based on my experience. You could have other problems.....let us know what ZF Doc says! He knows more about these trannies than I will ever know!
Old Jun 29, 2018 | 04:30 PM
  #43
dizwiz24's Avatar
dizwiz24
Originally Posted by Tom400CFI
Everyone has focused in on the elements that cause the "ZF RATTLE"....but that is a rattle. Are we sure that's the problem?
I think the problem may be something else. ZF rattle doesn't typically happen when underway/under load. And trans whine should diminish in higher gears....with none in 4th gear. I think it's something else.
yes it would occur on mine under load. Esp in first and if lugging it in too high of a gear up a hill.
the rocks in a can neutral noise is not an issue as thats not how i normally drive the car.
(if im at a drive thru, i turn car off - its loud for other reasons like exhaust)
Old Jul 1, 2018 | 06:52 PM
  #44
TheGreek!'s Avatar
TheGreek!
ZF doc called me yesterday and said that he would be here in Tucson tomorrow (which is now today) and asked if I could bring him the car today instead of next week. Of course I said yes and drove out to where he was at to let him drive the car. After he took it for a test drive he said that there is nothing wrong with the trans other than it having the infamous "ZF rattle" that these transmissions are notorious for. He said that his countershaft shim will fix it. He also thinks that I may have a solid clutch disc in it, if so he said to replace it with a sprung disc. I'm really glad that the trans isn't bad, that all I need to do is shim it and possibly have to replace the clutch disc.
Old Jul 1, 2018 | 08:49 PM
  #45
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Well....I was way off on this one! Glad the trans is good.
Old Jul 1, 2018 | 10:30 PM
  #46
STEVEN13's Avatar
STEVEN13
That’s great! If you still want the shim kit PM me. Also note that I ordered it in February of this year.
Steve
Old Jul 2, 2018 | 12:31 AM
  #47
TheGreek!'s Avatar
TheGreek!
Steve
I was going to buy your shim but ZF doc brought a shim kit and a few other ZF things with him and I felt kind of obliged to buy the shim from him since he took time out of his day to meet me and diagnose my trans for free. Sorry about that but I didn't want to say to ZF doc "no thanks, I can get one cheaper somewhere else", it just wouldn't be right to do that to him.
Old Jul 2, 2018 | 06:58 AM
  #48
STEVEN13's Avatar
STEVEN13
I totally understand. No problem. Now enjoy the Vette!
Old Jul 2, 2018 | 11:39 AM
  #49
856SPEED's Avatar
856SPEED
That pretty much went the way I thought. These trannies rarely fail, but often make noise when put behind a single mass FW; especially an aluminum piece like mine and yours!! I mentioned idle in mine since that is the most noticeable to me. But yes, under a load in higher gears you will hear it as well.
You are are one of many, trust me! That thing can rattle like crazy and will not a hurt a thing other than your ears!!
Old Jul 2, 2018 | 12:37 PM
  #50
TheGreek!'s Avatar
TheGreek!
I wish mine was mainly noisy at idle but its so noisy in gear under load that it sounds like the trans is coming apart. It might not hurt anything but it sounds like ****. When I brought it to the local car show last week a couple people that heard the car said "what's wrong with your trans?" I don't want to have to explain the trans every time I go to the show with it, I want it to stop making that awful racket. I'm gonna do what ZF doc said to do and hope it fixes it because I'm not going to put up with the awful noise it makes. Oh and speaking of the aluminum flywheel, I'm gonna get rid of it and put a stock dual mass flywheel back in it. I won a dual mass flywheel on eBay the other day for 150 bucks with free shipping (I was the only person that bid on it thankfully). I'm getting rid of everything aftermarket that's in it that could possibly contribute to the noise and replacing it with stock components. I'm gonna fix that noise one way or another, if it still rattles after I'm done installing the shim and replacing the flywheel and clutch disc I'll convert it to an automatic.
Old Jul 2, 2018 | 05:19 PM
  #51
856SPEED's Avatar
856SPEED
The dual mass alone will make a huge difference. It’s a heavy *** SOB like others have mentioned though.
At least you know now!
Old Oct 21, 2018 | 03:17 PM
  #52
TheGreek!'s Avatar
TheGreek!
Update:
Over the course of the last week I replaced the Fidanza aluminum flywheel with a stock dual mass flywheel and installed the countershaft shim kit from ZFdoc (and also installed a new pilot bearing, clutch disc, pressure plate, and throwout bearing) and the noise is gone! It's nice and quiet now, the trans no longer sounds like it's coming apart inside. The car has just been sitting in the garage ever since I bought it because I didn't want to drive it with that God awful noise, now I can finally start enjoying the car at last.
Old Oct 21, 2018 | 03:34 PM
  #53
AgentEran's Avatar
AgentEran
Update:
Old Oct 25, 2018 | 06:18 PM
  #54
1993C4LT1's Avatar
1993C4LT1
Good read for a guy like me who is going to buy a zf6 c4. Gad you got rid of the sound and are now going to drive it.
Old Oct 26, 2018 | 06:38 PM
  #55
TheGreek!'s Avatar
TheGreek!
Originally Posted by 1993C4LT1
Good read for a guy like me who is going to buy a zf6 c4. Glad you got rid of the sound and are now going to drive it.
I'm glad the noise is gone too. It sucked just seeing the car sitting in the garage and not being driven because of the trans noise. It's a '96 Collector Edition with an LT-4 engine, I wanted to drive it but just couldn't with it making that horrible racket. Now that the noise is gone I've driven the car more in the last few days than I have since I bought the car, I'm finally enjoying the car at last!
Old Oct 26, 2018 | 07:01 PM
  #56
AgentEran's Avatar
AgentEran
LT4s are fun to drive for sure!
Old Oct 27, 2018 | 07:09 AM
  #57
turbobuick33's Avatar
turbobuick33
What was causing the noise? What part did you replace?
To ZF six speed problem
Old Oct 27, 2018 | 08:44 AM
  #58
856SPEED's Avatar
856SPEED
It was well documented in this thread.
Old Oct 29, 2018 | 11:23 AM
  #59
mixalive's Avatar
mixalive
For a while there I was using that Amsoil Transmission oil. Then my transmission developed grinding between shifts. I started running Castrol TWS and the problem went away.
Old Nov 18, 2018 | 02:08 PM
  #60
DAVECAD2.0's Avatar
DAVECAD2.0
Default ZF Tranny
About 20 years ago just after a picked up a '92 LT1 I bought a brand new ZF 6 speed from a Chevy dealer who was going out of business. Had six in stock and selling for $600.00. With 150k on the clock I thought what a deal. It's a "blue" label and the original is a "black" label. What's the difference? Any way, now that I'm retired, have a lift. a tranny jack, and lots of time, and not knowing how old or the condition of the clutch and FW I'm going to swap it out. It has always had a grinding sound at idle with the clutch out. Just a little pressure on the clutch and it goes away. Always assumed it's the throw out bearing? Also the rear main seal leaks.
Reading these posts I'm not sure what to do about which clutch and fly wheel to use. It's got 175k on it now. Occational driver. Was thinking use a SMF and sprung disc?
TIA, Dave.
