Starting Problem
Old Jun 23, 2018 | 10:06 AM
corv95's Avatar
corv95
Cruising
Default Starting Problem
Have a starting problem with my 1995 C4 coupe, LT1, automatic. When turn key to on get a click and nothing else. If turn key off and immediately back on , car starts right up. Does not happen every time but quite often. Has anyone else experienced this and have an idea what may be issue?
Old Jun 23, 2018 | 10:40 AM
PatternDayTrader's Avatar
PatternDayTrader
Sounds like a bad starter.
Old Jun 23, 2018 | 02:57 PM
3D-Aircrew's Avatar
3D-Aircrew
Or a bad starter solenoid ... much cheaper.
Old Jun 24, 2018 | 08:37 AM
corv95's Avatar
corv95
Cruising
Originally Posted by whalepirot
The contacts deterorate with use. The can be cleaned up with a file or the disk that rotates can be reversed; each free and effective. If you buy, suggest new or reman, not rebuilt.
Thanks for the info, will try that first before a starter.
Old Jun 24, 2018 | 08:50 AM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Yes, try the contacts cleaning first especially if you are getting intermittent (which you are) clicks. Is you battery full up?
Once you have the car going, take a swing by Auto Zone and ask them to put a meter on your charging system. A low battery or less than optinam charging system will make the relay click as well. You will have an idea in a few minutes if your charging system is up to snuff.
Old Jun 24, 2018 | 08:54 AM
wingsfan1950's Avatar
wingsfan1950
5th Gear
I have the same problem.
Old Jun 28, 2018 | 09:24 AM
fake's Avatar
fake
Pull the starter and rebuild it localy. these new and remanufacture are all low bid parts.They also have mexico labels on them or China, Support your local rebuilding shops.
Old Jun 29, 2018 | 08:36 AM
corv95's Avatar
corv95
Cruising
Thanks for the info, like local better.
Old Jul 17, 2018 | 04:18 PM
wingsfan1950
5th Gear
I started with the battery. Battery only putting out 11.5 amps. Put new battery in and fixed the problem. New battery shows 14.5 amps.
Old Jul 18, 2018 | 08:01 AM
corv95's Avatar
corv95
Cruising
Thanks for the info
Old Jul 18, 2018 | 01:30 PM
pcolt94's Avatar
pcolt94
Everybody is correct.
Very common problem.
When you do to change out, you won't think the starter is going to come out as the space is real small. But it will as the starter is smaller than you might think.
Disconnect battery first.
Old Jul 18, 2018 | 04:50 PM
Natrlone93's Avatar
Natrlone93
Could be as simple as a loose battery connection. Happened to me before.
Old Jul 18, 2018 | 08:00 PM
Dt86's Avatar
Dt86
Wow! That's some battery!
Old Jul 19, 2018 | 08:18 AM
corv95's Avatar
corv95
Cruising
Yea, space looks small. Always disconnect the battery when working on electrical. Thanks for the reply.
To Starting Problem
