fuel pump?
Old Jun 30, 2018 | 06:06 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Originally Posted by Williamlindsey
Replaced the fuel pump, and strainer. what pressure should i be getting?new pressure test gauge connected to schrader valve cold no start just key on I get 40 psi after start it drops to 36 and stays there. shut off it doesn't bleed down. fuel filter is next runs like **** but doesn't die on me
You might want to get a fuel pressure gauge and do a REAL test. First, connect it to your schrader value at idle and you should get +,- 40. Then tape the gauge to your windshield and take your car for a ride. You should see the pressure increase as you accelerate meaning your three points of failure (pump, filter FPR) are in order. If you are not getting increasing pressure (50ish at WOT) then you have issues.
