Help with disappointing dyno results
Going back to what you said....I don’t know I would do this project today....why????
I had no idea muscle car era 2.0 was going to the levels we are seeing today....technology has has grossly improved in the new cars and they do everything so efficiently with a huge aftermarket. Don’t get me wrong, this car will stay with me since it’s a quality build....but If I were you, buy an LS with a whole car wrapped around it. Computers and televisions from the 80’s and 90’s were great at that time, but could you imagine trying to convert one to your big screen HD set??
No think about the car from 1960 and compare it to one from 2000.
40years make a big difference. We are talking about a fuel injection and engine designed 40 years ago, produced on manufacturing methods from 40 years ago.
Not only the technology, but emissions, CAFE, ability for the engine to fit into different platforms... etc. It's not so easy to just offer as an "option". There is a reason why cast manifolds are still used and it is not because it is the easiest way to make power. It's a series of compromises resulting in an acceptable solution to many constraints.
Somethings I know very well. Longer intake runners make more power down low. Hence the name "Tuned Port" you can tune the ports for certain RPM ranges. Same for head port length and cross sectional area.
1. Cost. "A few hundred bucks" is a ton of money to add to a cars COST (not price). I guarantee you that the ROI isn't there; most people wouldn't pay what the Retail would end up being on that part.
2. To meet all of GM's criteria, the headers would have to cost more than "a few hundred dollars", most likely.
3. Fitment
4. Under hood heat
5. Durability
6. Cat light off time
7. Passenger compartment heat
...for starters.
Dyno tests have shown the value of LT headers on the L98, both in F-bods and 'Vettes...since those cars came to market, so for there is about 30 years worth of data on this topic.
To go 20 more inches at least for a 91 is trivial as is the cost of tubing when buying tubing in the volume used already.
2. I don't run GM's engineering department possibly you do or have personally read their spec's for an exhaust system and can point them out verbatim.
3. Every Y body and F body is the same as they don't make any other partspecifically for each car.
4. A couple of heat shields as needed already changes little. By nature it is not loaded with precision dimensions beyond normal stamping equipment.
5. My 91 had original exhaust when I got it as a 17 year old car my Pontiac has 16 year old exhaust. I suspect OEM exhaust is wildly better than any after market one.
6. You mention all this heat to deal with so pretty much takes care of light off especially with heat shields to hold it in and out of engine compartment.
7. Compared to the cat right under the center of the passenger compartment it does not seem overwhelming as a problem and if it showed up fixes are very simple and cheap.
The ability to do accurate work and do it cheaply is what building anything in volume is what factories can do when dealing in tens of thousands of identical part. Current aftermarket headers and custom exhaust is expensive and at times has problems fitting due to low volume and implied value tht the customer will tolerate.
My take on it do with what you will. My only experience in the automotive world making multiple identical parts is with the Calloway B2K engines. I managed the shop floor producing the engines as a subcontractor shop. 435 more or less (it has been a long time ago) engines and even at that level buying pallets of plain boxed parts is wildly cheaper than might be imagined.. The actual work of building them was much cheaper than you could every do one two or a dozen. We had milling and boring machines that the setup did not change for years.
My thoughts free so take them for what it is worth rather than a debate and personally adding 50 HP as claimed by header companies and their shills on a stock L98. If it was that easy GM would find a way to do it as the big sell on the LT1 was 300 hp last looked 250+50 is the same 250. Not up for a debate but I don't think things are as black and white as you allude to.
1. Have you seen long tubes made? It's more than just the bent tubes, it is also the welding and flange flatness. Then cleaning up the weld beads at the flange. The time to produce them is a lot more, requires a lot more material, and require more specialized equipment. As an Automotive Engineer that actually has worked for OEMs, Tier 1 and Tier 2 suppliers... a lot in CNC Machining of cast parts and welded assemblies I can assure you... a cast manifold is cheaper and not by just a few hundred bucks.
2. Have you installed long tubes on many cars? Space is a major issue often requiring the removal and re installation of many components. Starter, steer shaft, steering rack, Air conditioning... I have done it on a few cars. In the mass production world, the engine has to be a drop in on the line and once a part is on, they don't remove it for something else. This does no apply to very limited production or conversion vehicles. This is why you could get cars from SLP with headers. It was done after the car left the assembly line.
3. Emissions... how many long tube headers do you know... true long tubes, that actually get an CARB ID?
4. Factory exhaust on most cars are still mild steel... mild steel is mild steel and stainless is stainless and aluminized is aluminzed. Depending on what you buy or your car is equipped with, the results are based off material.
There is a reason a set of coated long tube headers that actually fit and don't blow out gaskets every 2500 miles are north of $2500. There is a reason why hot rodders have been using long tubes for over a half century and OEMs are still not. It is not because they don't make more power. It is because of fitment, cost, and emissions.
Also I don't know that they had a whole lot of CNC machines in the mid 80s and even with modern CNC we still have cast pistons, cast heads and cast engine blocks in the vast majority of vehicles built today. If the cost difference was really trivial those parts would be forged from billet.
The other problem with long tube headers is space and fitment. You would need different headers for F bodies and Y bodies meaning different full up engine subassemblies. To be honest production variances might actually make it impossible to do in volume. I have never installed long tube headers on either an 80s vette or camaro, but I have installed them on a lot of other cars and you get two identical cars, same year, same engine and two identical sets of headers and they will fit on one car like a glove and need to be modified for the other car. Not anything major but you would need to dimple the header here or grind off a small part of the cars frame there. That kind of fitment process is routine with headers but would cost thousand of dollars on a moving production line. Maybe an OEM could do better in volume, but none have yet to my knowledge for a high-volume application.
