Cruise Control
Old Jul 17, 2018 | 05:55 PM
cohoskip's Avatar
cohoskip
Default Cruise Control
The cruise control on my 86 auto trans stopped working. The fuse is good. Any suggestions? (about a fix, that is )
Old Jul 17, 2018 | 06:15 PM
84 4+3's Avatar
84 4+3
Try lifting up on the brake pedal while driving. If that works, adjust the brake light switch.
Old Jul 17, 2018 | 06:44 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Check your vacuum hoses as they could have developed cracks around the tips. If so, just trim them back about 1/2 inch or until you remove the cracks.
Old Jul 18, 2018 | 01:08 PM
ctmccloskey's Avatar
ctmccloskey
The cruise control in our 1988 Coupe died one day and I looked under the hood and there were two vacuum leaks, one was at the EGR solenoid and the second was at the cruise control device near the battery. I cut off the ends and the cruise came back to life. Since then I have put little tie wraps on the vacuum lines to secure them as I cut off 1" from the end of each one I worked on.
Best wishes getting your Cruise Control back to work again, it shouldn't be too bad as you can get to most of the parts, most of the time!
Old Jul 18, 2018 | 01:41 PM
pcolt94's Avatar
pcolt94
I was going to make these suggestion as well.
The brake switch is a common problem.
Old Jul 18, 2018 | 03:35 PM
cdm747's Avatar
cdm747
St. Jude Donor '17-'18-'19-'20-'21-'22
The contacts on the brake switch on my 88 were corroded. Changed the switch and no problems since.
Old Jul 19, 2018 | 03:26 PM
cohoskip's Avatar
cohoskip
Thanks for all the help, I shall check it out...
Old Jul 19, 2018 | 04:09 PM
hcbph's Avatar
hcbph
If you have a manual tranny, know there's a kickout switch on the clutch also.
If you don't have a FSM, get one. There are diagnostics in there that should take you through fixing it.
Old Jul 19, 2018 | 05:44 PM
gerardvg's Avatar
gerardvg
Check the brake switches with multimeter, I had an internal failure in one of the switches.
The contact inside broke making a poor connection, would drop out of cruise at random and one day no more cruise.
Check the vacuum hoses and don't forget the dash controls the cruise control also, look at Batee's website for schematics www.batee.com
Good luck
To Cruise Control
