VATS... Maybe
Old 07-21-2018, 08:37 PM
rbates74
rbates74's Avatar
Default VATS... Maybe
If I have a chip burned with a VATS disable, should the security light still be flashing at me all the time?
I have some other issues I am dealing with that could easily explain the no start, but they could be unrelated.
I just didn't think the security light should still be flashing so I wanted to approach that angle as well.
Old 07-21-2018, 11:27 PM
Kevova
Kevova's Avatar
Year? The content theft deterrent will make security light flash if door are open or tamper switches are damaged.
Old 07-22-2018, 09:49 AM
rbates74
rbates74's Avatar
It's a 1990
Old 07-22-2018, 01:55 PM
Kevova
Kevova's Avatar
What are the other symptoms? VATS disables starter, fuel pump, injection. It's possible you chip is not bypassing VATS. Why did you change chip?
Old 07-22-2018, 04:51 PM
Purple92
Purple92's Avatar
I can't speak for all instances - but I believe that when you turn the VATS system off at the PCM level - the PCM just ignores the resisitor code issue. So - YES - it's quite possible that the security light would still be flashing - the PCM has simply been instructed not to care....
Old 07-22-2018, 06:13 PM
rbates74
rbates74's Avatar
Thanks gentleman, I will focus on coil issues.
Fuel pump kicks on for a few seconds and then cuts out. Starter cranks.
I tried starting fluid with no change, telling me that fuel is not the problem, still could be A problem, but not THE problem.
I did an engine upgrade, more cubes, bigger valves, headers, bigger injectors and an HSR.
To VATS... Maybe
Quick Reply: VATS... Maybe
