Diagnosic tool
Old Aug 7, 2018 | 02:23 AM
Impala59's Avatar
Impala59
1st Gear
Default Diagnosic tool
Hi.
Is there anyone who can recommend a diagnosic tool, to find out fault code on engine on a 93 Corvette.
A tool i can buy on Ebay or somthing.
Best regards
Raymond
Old Aug 7, 2018 | 07:27 AM
hcbph's Avatar
hcbph
I've got an Inova 3140 (IIRC) that I use on ODB1 & 2 vehicles and so far it's worked on them. My Vette is an ODB1 while the truck and van are ODB2.
Old Aug 7, 2018 | 07:35 AM
fake's Avatar
fake
Owning a 93 i have owned the nova etc. I have found nothing really tells you much. Buy the service manual and that will be a plus. Other wise under your left knee there is an area were you can read codes for free but you will need the two book service manual to troubleshoot and a paper clip . Good Luck!
Old Aug 7, 2018 | 09:49 AM
pcolt94's Avatar
pcolt94
By using the on board diagnostics it will read the CCM, ECM and EBTCM and some others too. It's free and it works great.
To buy a Tech 1 today will be hard to find and not cheap. And a Tech 2 is thousands a lot for a consumer.
I have a Tech 1 (for 12 years) and you can do more with them than just scan. They are a great tool if you can find one with the proper software.
There are some scanners that will read OBD1 and you will get some of those answers on the Forum. But they will only read the ECM and not all the other modules the built in diagnostics will do.
Old Aug 7, 2018 | 11:32 PM
aklim's Avatar
aklim
I'm using an Auto Xray and it does give some data from the ECM. So does ALDL Scan with a 3120 Electronics bluetooth unit. Paperclip gives me about what I paid for, information wise. The ECM is crude, relatively speaking and it takes quite a bit to get outside of the plausible values where a code is thrown.
Old Aug 8, 2018 | 10:43 PM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
You can recover the codes by following the steps here:
http://www.neilkline.com/Tech%20Tips/obdcodes.htm
then you can use the search function to find a list of the code translations for your year.
To Diagnosic tool
