Why do C4s drone?
Old Aug 17, 2018 | 06:14 AM
  #41
barchetta1's Avatar
barchetta1
Originally Posted by mikeinPA
how did you program the over drive? Is that a chip?
Jet DST tuner.
Old Aug 17, 2018 | 05:43 PM
  #42
SpedRacr93's Avatar
SpedRacr93
Originally Posted by L98auto
Sorry, I know this topic has been beaten to death. I don't want to start a long thread about which exhaust combinations drone, how Corsa is the only way to go, how Flowmasters are terrible etc., etc. I'm more curious in the cause of C4 drone. I have extensive wheel time in C2 Corvettes and they don't drone despite having a glass enclosure behind the driver. I've driven C3s and most don't drone. What is it about the C4 that causes drone? All the earlier generations mentioned have mufflers in similar locations which rules that out. I'm aware of exactly what drone is, but specific causes in the C4 puzzle me (especially since it doesn't appear to affect earlier cars. Thoughts about the science behind it welcome, not looking for a brand shootout. Thanks for any insight into this.
My opinion is Camshaft Duration causes most of what you hear and is the reason that C2s and C3s don't have it. Lift on the lobes is relatively similar across many of the engines, but the durations were much shorter starting with the C4s to improve throttle response and increase low end torque. My C4 does not drone, but my cam isn't stock either.
Old Aug 17, 2018 | 07:06 PM
  #43
barchetta1's Avatar
barchetta1
Wondering, how did you come to that opinion?
Old Aug 17, 2018 | 07:26 PM
  #44
SpedRacr93's Avatar
SpedRacr93
Well... I'm not sure how else to say it.
The OP makes the point that C2s and C3s he has been in didn't drone. There are lots of factors that can come into play, one most definitely being that those C2s and C3s that he drove didn't lope along at 70 MPH at 1200 RPMs, therefore it's hard to make a direct comparison unless you compare exhaust noise at RPMs. My only point of reference (other than I have driven several C2s and C3s as well that didn't drone at cruise speed) is that the C4s that I have driven, that have performance cams and performance exhaust systems don't drone at cruise speeds. There are lots of factors that come into play with respect to camshaft differences, so I'm only comparing the factory cams with performance exhaust.
Old Aug 17, 2018 | 07:41 PM
  #45
barchetta1's Avatar
barchetta1
thanks.. interesting conclusion. Another reason to dump $1200 into mine to have a cam installed and tune it.
Old Aug 19, 2018 | 12:44 PM
  #46
Bigpoop's Avatar
Bigpoop
Answer to original post....
To remind you of your first wife.
Old Aug 19, 2018 | 01:20 PM
  #47
barchetta1's Avatar
barchetta1
This explains why every one of us is on the same quest to be rid of "it".
Old Aug 19, 2018 | 05:50 PM
  #48
Bigpoop's Avatar
Bigpoop
Cheers
Old Aug 25, 2018 | 12:17 PM
  #49
barchetta1's Avatar
barchetta1
Originally Posted by 2LZ
Tremendously = Took it from a bad drone at certain R's to a much more muffled sound. Does it still drone? Some, but it's definitely livable.
Here is the material I used. Applied very nicely.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
After I removed the carpet and pad, I tapped on the floor pan. It's like a hard plastic bass drum. I can see why there's some sound issues.
So I purchased this kit and in facts it coming today. But when I started to pull up my carpet I noticed it already has sound deadening material. Is this dynamat type stuff going to help? And I suspect its all glued down.. dont think its wise to try and remove.. did you remove yours?
Old Aug 25, 2018 | 12:22 PM
  #50
scorp508's Avatar
scorp508
That old jute is junk today. It provides very little sound absorbsion and if it gets wet it retains moisture. It should pull right out. Only a couple spots in my 87 had very light adhesive on it
Old Aug 25, 2018 | 12:28 PM
  #51
barchetta1's Avatar
barchetta1
Looks like over the boxes its glued down. Now I need to figure out how to get the carpet out. I guess I just start removing screws.
Old Aug 25, 2018 | 12:32 PM
  #52
scorp508's Avatar
scorp508
Tons of them. All the rear trim has to come out. There are a couple hidden discs under the rear hatch latch trim too the carpet goes up and over a couple of bolts.
Old Aug 25, 2018 | 01:02 PM
  #53
cv67's Avatar
cv67
St. Jude Donor '05
Short exhaust system youre sitting right on top of.
as said the interior acts like a speaker box. Glass amplifies sound, too.
Dynamat wont make a car quiet...it may tone down a certain frequency some but dont get your hopes up
Get a quieter muffler thats where the solution is. If a stock type is too loud then a sports car isnt for you.
See guys complaining their stock C6 is too loud, not sure what people expect!?
Old Aug 25, 2018 | 01:05 PM
  #54
barchetta1's Avatar
barchetta1
Thanks man, you are right.. Im going to go ahead and sell it rather than try and reduce drone a little. Going to look at a nice Buick. Thanks for the fantastic advice.
Old Aug 25, 2018 | 10:00 PM
  #55
Pwnage1337's Avatar
Pwnage1337
Build 1/4 wave resonators
Old Aug 25, 2018 | 11:14 PM
  #56
Dt86's Avatar
Dt86
I fixed my drone problem for less than $20. I made a thread on it.
Old Aug 26, 2018 | 04:40 PM
  #57
ddahlgren's Avatar
ddahlgren
How about a link to the solution..
To Why do C4s drone?
Old Aug 26, 2018 | 05:22 PM
  #58
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
^^Right? It makes way more sense for every one to search for it. He's using his DtSense.
Old Aug 26, 2018 | 05:39 PM
  #59
Dt86's Avatar
Dt86
My apologies, I was pretty tired when I posted.
https://www.corvetteforum.com/forums...xperience.html
Old Aug 26, 2018 | 08:40 PM
  #60
v8vette84's Avatar
v8vette84
Is it really that hard to search his threads?
