Hey guys, I have an 89 with the ZF 6-speed. I have the build sheet on my car and it appears to have 3;33 gear ratio. I think the other option was 3:54 ratio. I was thinking of maybe changing my gears to the 3:54s. Is this a very hard thing to have done? Also where would I get the gears? Any input is appreciated. Thank you in advance.
Its not particularly difficult if you have done it before, but there's a pretty steep learning curve if you haven't.
Im sure Jegs or Summit can sell you the gears and the other required parts.
Planning on having it done by my regular mechanic. I will go search out what Summit has for gears and parts recommended.
If it is a 3.33 it would be a very desirable gear for some. I'd consider maybe a purchase of another rear in whichever ratio you desired and a sale of your 3.33 assembly. I won't offer up any ratio that you should consider but I know that if it were me I'd be selling yours as a complete unit. I'd think you could (of course based on condition) break 'even' or perhaps make a little on the change. If you found someone with a 3.73 or 3.54 that was interested in the 3.33 that you could drive to confirm condition it would be to your advantage.
when corvette came out with the zf 6-speed, they used the 3.54 gears till about nov - dec 88'. then they started using the 3.33 gear for the rest of the year. there were more 3.33's out there than the 3.54's. then in the 90' year they started using 3.45, i believe, until the end of the c4 run.
I have an automatic with 3.54's and I should of done 3.73's. You have a six speed, you could possibly do a 4.?? ratio. It depends of what your goal is??
Nobody has ever wished they would have stayed with a higher gear (numerically smaller). I had a 3.55 in a Mustang and was on the fence between 3.90 and 4.10. I received this advice and went witht he 4.10. Absolutely loved it and that was with a 5-speed. With the 6-speed, go ahead and go lower. You won't regret it.
What I found with the 4.10 was I actually got better gas mileage in town as I was in a higher gear in the transmission and actually turning less RPMs at 35-45mph. Yes highway suffered a bit, but nothing as bad as some may paint it. I know a lot of LT1/LS1 guys go 4.11 with their 6speeds. I highly recommend you go this route to. Not sure what Dana offers in the range, but it will feel like you gained 50hp.
The stock L98 isn't a high revver...only good to about 4500. If you have the stock TPI intake you might not want to change gears and do something with the intake first...Accel TPI, Superram, Mini Ram, Stealth Ram ...etc .
What? Unless you are running a 1/4 mile and will run out of RPMs at the top of the track, this is just nonsense. I have read and heard this so many times. A TPI is perfectly happy cruising at 2500RPMs and he has a 6 speed. This isn't a race car where limiting top speed will be an issue around the track either. Go low and enjoy the torque multiplication. Yes, each gear will be shorter.
Diesels aren't high rev motors either, the tow package still comes with a 4.XX gear.
I put a set of 3.73 gears into an 85 d44 vette .I got the gears from ebay.They came out of a jeep grand Cherokee.the d44 is actually a dana 44s that is the same diff in a Viper.I had to grind above and below the ring gear because the ring gear would not fit into the case.If you want to save money pull the diff at home and take it to a shop for the actual gear work.
