1992 ecu question
Old Aug 18, 2018 | 11:35 AM
vetteguy8899's Avatar
vetteguy8899
Default 1992 ecu question
Good morning, so last night I decided to start the 92 after its been sitting for a couple of weeks, and it ran horrible, then fine, then horrible etc. this morning I opened the hood making simple checks of connections etc, started it and it ran like a top, until I closed the hood it almost died.... opened the hood again and discovered when I tapped on the ecu it greatly affected the way the car ran, long story short, my ecu needs replacing or refurbished.. does anyone recommend a place to refurbish the ecu? thanks in advance,
Dana
Old Aug 19, 2018 | 03:46 AM
MaineJim's Avatar
MaineJim
Dana
It just might be a connector,carefully wiggle them one by one and see what happens.
I got a 92' as well,have not looked for an ECU rebuilder,will see what the rest say here.
Good luck with it.
Old Aug 19, 2018 | 07:55 AM
bjankuski's Avatar
bjankuski
Advanced auto can get you an ECU if you need it.
Old Aug 19, 2018 | 08:02 AM
1stVetteFinally's Avatar
1stVetteFinally
I had to get the ECM in my previous '92 rebuilt. I used SIA Electronics. Cost about $200 total, turn around took about 5 days. Never had a issue with that ECM again. http://siaelec.com/product/16159278-...repair-return/
Old Aug 19, 2018 | 09:44 AM
vetteguy8899
Good luck with it.
thanks I did check the connectors I do believe its internal
Old Aug 19, 2018 | 09:45 AM
vetteguy8899
good to know thanks!
Old Aug 19, 2018 | 11:49 AM
fake's Avatar
fake
You have corrision on your terminals Open it up throw a hair dryer on it, with battery disconnected. Wear anti static wrist band ( Staples can help you) when handling it it Hook battery back up after looking for visual corrosion and clean with electronic contact cleaner . Some times a soft tooth brush can remove un wanted ferrous metals.Last resort SIA electronics stay away from the parts stores on this sensitive item.
Old Aug 19, 2018 | 12:32 PM
JimLentz's Avatar
JimLentz
Old Aug 24, 2018 | 11:12 PM
skinnyt's Avatar
skinnyt
ether way look at buying ( Deoxit D5)
best product I ever used !
I mainly use it on old stereos,old arcade games and pinballs, buts works great on everything electrical...its a must have if u ask me
Old Aug 24, 2018 | 11:23 PM
MaineJim's Avatar
MaineJim
Yup love Deoxit,use it on my older ham radios.
To 1992 ecu question
