93 Wiring plug info
Old Aug 23, 2018 | 01:49 PM
radar502's Avatar
radar502
Default 93 Wiring plug info
Any way to identify wiring plugs on my 93 Corvette base , The plugs have numbers can the plugs be identified with these numbers or a wiring diagram . I cam find much .. Thanks ..
Old Aug 24, 2018 | 08:25 AM
radar502's Avatar
radar502
Originally Posted by ihatebarkingdogs
The way I identify wiring connectors is by the location in the car, the harness they are part of, the number of wires, the colors of the wires, the type of connector, and what they plug into if known. Using the FSM, you can find any connector with the aforementioned info. For me, wire colors and location are usually enough.
Thanks , I lived in Old Torrance for a few years loved the place..
Old Aug 24, 2018 | 08:51 AM
WVZR-1's Avatar
WVZR-1
If you have the FSM rely on the wiring diagram, the page after the diagram has connector reference and will direct you to 8A-201 section for a vehicle view (for some) and 8A-202 section for identification. 8A-201 and wire colors should nearly always be sufficient. The 8A-201 section of the FSM is quite valuable for much of the particular year it covers.
To 93 Wiring plug info
