94 Oil Temperature Sensor
Old Aug 23, 2018 | 11:32 PM
Impala Balko's Avatar
Impala Balko
Default 94 Oil Temperature Sensor
I have a 94 Corvette with the LT1 and I need a oil temperature sensor. I am coming to the realization that this part is hard to find. Now I found a listing on eBay that has one for sale however they say it fits the LT5 not the LT1. Does the Lt1 and LT5 use the same sensor are they comparable. The picture of the sensor looks identical to the one that came off my motor.
Old Aug 24, 2018 | 03:19 AM
WVZR-1's Avatar
WVZR-1
GM # 10096136 or equivalent from a local source would be correct for your LT1 - it does appear to fit some LT5 and also L98.
Old Aug 24, 2018 | 07:04 AM
Impala Balko
so it should be safe to say that a sensor for a 94 LT5 should fit my 94 LT1
Old Aug 24, 2018 | 08:24 AM
WVZR-1's Avatar
WVZR-1
NO - I don't believe a '94 LT5 is the same as the '94 LT1. The electrical connection is the same but that's it I believe. Take the 10096136 to a 'local' AP Store. Most I'd think can help you. NOT IN STOCK but 1 or 2 day. NAPA or AutoZone maybe.
NOT - 'SAFE TO SAY'
Old Aug 28, 2018 | 11:41 AM
Impala Balko
Does anyone know where I can get this sensor, everywhere I look it's discontinued
Old Aug 29, 2018 | 09:33 AM
Impala Balko
Could I run a 1/4" to 3/8" union adapter to adapt the LT5 sensor to the LT1 block seeing as the electrical connection is the same
To 94 Oil Temperature Sensor
