Fuel pump recommendations
Old Sep 16, 2018 | 09:19 AM
fredk's Avatar
fredk
Default Fuel pump recommendations
I have been tracing my non idle issue on my 93. I replaced the fuel filter and no change. I checked fuel pressure and it's at forty but it will not hold at all. Fuel pump next, but what brand ??
Thanks Fred
Old Sep 16, 2018 | 10:24 AM
Pwnage1337's Avatar
Pwnage1337
I would check the regulator before the pump. Pumps generally just fail and don't work at all. The fact that you have pressure then drops makes me think regulator.
Old Sep 16, 2018 | 10:45 AM
fredk's Avatar
fredk
Thanks, will check
Old Sep 16, 2018 | 10:59 AM
jph46's Avatar
jph46
Thanks Fred
How many miles on your 93? I was chasing down a ruff idle on my 93, (66k miles) I replaced everything from the injectors back to the fuel pump. Went with the Bosch III injectors from FIC and got my fuel pump from Racetronix, in Markham, Ontario. 4000 miles later running like a fine tuned watch. If your losing pressure it could be a number of things, start with the injectors for leaks and the fuel pressure regulator. With mine the injectors where leaking, so the Bosch injectors took care of my ruff idle, replaced everything else for peace of mind.
Old Sep 16, 2018 | 02:42 PM
jv9999's Avatar
jv9999
Leaking injector(s) most likely, FP regulator next, then the fuel pump.
Old Sep 17, 2018 | 08:25 AM
aklim's Avatar
aklim
Thanks Fred
Why is it not holding? Fuel pressure regulator? Fuel injectors? Pulsator at the tank? You need to isolate it.
Have someone turn the key to run and not crank, At that moment, crimp off the return line. See if the pressure holds. If it does, look at the regulator next. If it doesn't, repeat test and crimp off the feed line. If it doesn't hold then, go with injectors.
Old Sep 17, 2018 | 09:01 AM
fredk's Avatar
fredk
Thanks for the info guys. I did my top end build in 2005 when everything was replaced and put about 4000 miles since. So will track down soon I hope, as it will only be on the road for another month.
Old Sep 25, 2018 | 09:49 AM
fredk's Avatar
fredk
I finally got time to check the old girl again. No fuel in the vacuum line to fuel filter regulator. Checked oil and sure smells of gas. Can I assume that I have a leaking injector ?? It also does backfire sometimes as well, must be too much fuel in a cylinder.
Old Sep 25, 2018 | 09:57 AM
jv9999's Avatar
jv9999
Sure sounds that way. Are the injectors original? You can test further by watching the fuel pressure, but if the oil is diluted I wouldn't run it until I had new/rebuilt injectors in there and changed the oil. It's possible for a leaking injector to hydrolock the engine bending and breaking things. Also, diluted oil doesn't lubricate very well.
A lot of people here use https://fuelinjectorconnection.com/
Old Sep 25, 2018 | 10:24 AM
scotth48's Avatar
scotth48
Originally Posted by ihatebarkingdogs
As long as there is some, fuel pressure doesn't have anything to do with idle quality. Marginally-performing fuel pumps usually show up as drivability issues, not idle quality. Please expand on the problem you're having. The way you word "non-idle", to me suggests it won't idle if you take your foot off the throttle. If = yes, things to check would be vacuum leaks, Idle Air Control motor, EGR valve is closed; things of that nature. If you have access to a scanner, info like IAC position, EGR position, BLM and INT fueling, even O2 sensor activity may help focus attention on the culprit.
As far as "fuel pressure drops quickly" when pump shuts off: My experience has been that engines do NOT care one iota what the fuel pressure is when iit is not running. As long as the pressure comes up to spec quickly enough to allow starting, especially with cold oil and temperatures, who cares what it is at rest, or how long it takes to go to zero? Check that the vacuum line on the regulator doesn't contain fuel (it will idle black smoke rich if it does), and that the oil isn't fuel diluted from a very leaky injector (highly unlikely), and forget about the pump if it is easy to start first time of the day.
i would also check the charcoal vapor return line.
Replaced the tank and had to clean out the line that was plugged with all those little bits of charcoal witha piece of stif wire and a vacuum from the sensor all the way to the canister.
Old Sep 25, 2018 | 10:29 AM
aklim's Avatar
aklim
If they are multec injectors I would definitely dump them so I can run ethanol gas which is all over instead of being forced to a couple of gas stations. If not, just get a reman set and be done with it
Old Sep 25, 2018 | 12:33 PM
fredk's Avatar
fredk
They are not original they were replaced back when I did the top end. I thought the same thing about running it. The problem I have now is I don't remember what size injectors I put in back in 06. She puts 350 to the wheels after the tune I had. Thanks for the help.
Old Sep 25, 2018 | 12:35 PM
jv9999's Avatar
jv9999
FIC can clean and test what you have as well.
Old Sep 25, 2018 | 03:36 PM
aklim's Avatar
aklim
And tell you what you have, size wise
Old Sep 26, 2018 | 10:01 AM
fredk's Avatar
fredk
Problem is I live in Canada and it would be a load of paperwork to send them to the States. Any fellow Canadians know of anyone in Ontario that offers this service ?? I will post this in the Canadian section as well.
Old Sep 26, 2018 | 12:38 PM
fredk's Avatar
fredk
Just talked to fuelinjectorconnection they sound great. Emailed me all the paperwork required, thanks !!!
To Fuel pump recommendations
