module 9 code H27???
Old Sep 29, 2018 | 07:48 PM
adelii's Avatar
adelii
Default module 9 code H27 on a 93 6spd
trying to find this brake abs code and cannot find it. H27. the asr and abs lights do not turn off and I cannot clear the codes. Any help?
Old Sep 29, 2018 | 10:20 PM
pcolt94's Avatar
pcolt94
What year car? Look like yours might be 94 or 95.
DTC 27 in module 9 is LF wheel speed sensor circuit continuity malfunction (94 FSM). H is historic.
These codes need to be cleared using the buttons and speedometer display. I think 9.7 is the area that will clear the code. You can't clear it disconnecting the battery.
Old Sep 29, 2018 | 11:33 PM
adelii's Avatar
adelii
Its a 93 6 speed. I tried to reset the codes like you said. I was able to erase some other codes. but not the module 9 code. Left front wheel sensor sounds like a clue thank you.
To module 9 code H27???
