I have an 85 with the original wiring harness and I have installed TPIS Miniram and my shop told me I needed a new ECM. I bought Zip's programmable ECM and how they are telling me I need a different wiring harness, not necessarily a new one, possibly a plug in play one. What do you suggest, is this something I needed or should I be looking for a different shop. I was also told by the shop that the ECM is for a MAP intake not a MAF intake like I have. HELP!
Thank you in advance to everyone.
You can use your original ECM and MAF unit and just get a chip from TPIS to make the combination work. Sure you can use an afermarket ECM but it will require a new wiring harness.
I suggest you have the wrong shop. Nothing they have said is correct.
You can use your ECM, chip recommendation as outlined above from TPIS. The 85 uses a MAF not MAP unless you convert it over.
What I meant to say was the factory ECM would work. If you bought a new ECM that requires a MAP to measure air intake then you certainly would need to convert it to MAP and you will need a wiring harness for the new ECM you bought.
You always want to plan your parts around the labor supply as well to make sure both are accommodating to each other.
I was thinking that Zip programmable ECM would just plug in play. There was nothing on their website stating additional wiring or binging the plugs would be needed.
