Nedd Help PLEASE response issue
Old Oct 20, 2018 | 11:22 AM
zacks89's Avatar
zacks89
4th Gear
Default Nedd Help PLEASE response issue
someone please help. i spent thousands trying to fix my car i need to at this point.
new tps,maf,aic,fuel pump fuel filter, timed @ 6 , new plugs, new exhaust. rpm going up after i hit gas with delay. if i hiit gas slow no delay. thank you for your time in advance.
Old Oct 20, 2018 | 11:24 AM
zacks89's Avatar
zacks89
4th Gear
Default 89 corvette tpi 60 over
Old Oct 20, 2018 | 11:37 AM
3D-Aircrew's Avatar
3D-Aircrew
Default Welcome to the forum;)
Hey Zacks89 ...Welcome to the forum. Do you have a factory service manual? Without it you are in the dark about a lot of things. Sounds like you are describing hesitation which I think has a flow chart in the drivability section.
Old Oct 21, 2018 | 09:36 AM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
are you using a shop for the work?
To Nedd Help PLEASE response issue
