3" x pipe options
Old Dec 7, 2018 | 10:45 PM
littleredcorvette88's Avatar
littleredcorvette88
Default 3" x pipe options
Hi All,
What are some of the x pipes options you have run? I've been searching for some different set ups but they mostly come up with 3" inlet on the header side and 2.5 on the exhaust side or 3" header side to 4" exhaust side. Then when I find 3" to 3" some say it wont fit while others say it will.
Current set up is a 396 stroker with hooker headers 2151hkr 1 3/4" inlet to 3" collectors then it was mashed into a larger pipe and welded (this is where the cat once was and then it shoots out to two 3" exhaust pipes that run to the mufflers. At cruising speeds the car drones SO BAD I find myself turning the radio down when it's not even on. It's obnoxious and now is the time for a new set up after replacing/rebuilding engines/ replacing every part pretty much on the car except the exhaust over the past 11 years lol.
I hear an x pipe could reduce the drone and then some say that's not the case. What have you all found out to work best for great sound at idle and acceleration but low drone while cruising? Is an x pipe the answer or is there something better? Not looking to spend $2k on this but need to do something. Any info would be great!
Thanks!
Car is a 91 coupe
Old Dec 8, 2018 | 02:34 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
If you are near upper NJ there is a great custom exhaust shop (Mufflex) that could build what you want.
Old Dec 8, 2018 | 10:33 AM
Kevova's Avatar
Kevova
A good muffler shop with a pipe bender should have not problem making what you need. Only problem would be lack of cat converter, so you want to call a head. They could make it for you and leave it for you to install.
Old Dec 8, 2018 | 10:53 AM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
The X pipe will certainly reduce the drone but not eliminate it completely. To reduce drone you will need a set of mufflers that work on "pressure wave cancellation" rather than sound absorption.
IMHO stick with 2.5 pipes out the back rather than the 3 inch. With headers you will have already pulled most of the exhaust advantage out of the engine. The X pipe will give an ever so small "scavenging effect" and the pipe size will have very little (very little) effect on you engine unless you are running super high HP and at the upper RPM (5.5k and above). And the gain will be minimal (5hp-ish)
The biggest down side of the 3 in pipes will be fighting clearance issues under your K frame. Yes, many have successfully done this with no issues, but an equal amount will have the pipe tap-tap-tapping on acceleration and driving. If you think drone is bad couple a healthy drone with a metallic tapping noise. That will drive you bat **** crazy.
This is my clearance with a 2.5 Corsa system. Imagine another half inch?
Old Dec 8, 2018 | 12:57 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Originally Posted by littleredcorvette88
Hi All,
Thanks!
Car is a 91 coupe
I had a serious drone issue on my '69. I welded up a removable H pipe between the header reducers (the most efficient placement). Five bucks worth of materials (and a bit of my cheap labor). Made a very noticeable reduction in drone noise (and an improvement in driving enjoyment). Still get compliments on how good (and comparatively quiet) the engine sounds at WOT. Cheap, easy, and effective.
Old Dec 8, 2018 | 01:51 PM
RetroGuy's Avatar
RetroGuy
Since you already have a unique setup, I'd suggest a custom muffler shop too. Have them make a X-pipe or H-pipe that could be temporarily installed (muffler clamps, not welded) to see/hear if it makes a difference. Then get the one that works welded-in.
Old Dec 8, 2018 | 09:34 PM
qwiketz's Avatar
qwiketz
Not sure if you are looking for some quieting, but dynomax has an ultraflow dual 3" in and out muffler with an internal x pipe. I was thinking of installing one on my car to replace the b&b 3" resonator when I redid my exhaust (never got to it)
Old Dec 9, 2018 | 10:35 AM
RetroGuy's Avatar
RetroGuy
Magnaflow makes a similar internal X-pipe type resonator that could work.
Old Dec 10, 2018 | 09:30 AM
Mike Holmen's Avatar
Mike Holmen
I made a home made 3in exhaust on my car, works pretty decent and hasn't hit anything yet. I think it is even quieter at cruise than my original 2in exhaust that the car came with. Summit has a bunch of x-pipes that work. I don't have an x-pipe, but it wouldn't be to hard to make. If you want some pics, I could snap off a few, but looks very similar to Bills. I don't run any mufflers under the car, just 3in flow masters at the rear. I also have headers on my car.
Old Dec 10, 2018 | 11:08 AM
littleredcorvette88
I currently have the 3" but if that's not needed for HP then I agree the 2.5" would be easier to fit. Does your system include an x pipe?
Old Dec 10, 2018 | 11:11 AM
littleredcorvette88
Any idea which setup would be better for HP and sound X vs. H?
Old Dec 10, 2018 | 11:12 AM
littleredcorvette88
Do you know the model number on this x pipe?
Old Dec 10, 2018 | 11:13 AM
littleredcorvette88
So is your set up - headers, straight pipe to mufflers in the rear? Any drone at all and is your engine built or stock?\\
Old Dec 10, 2018 | 11:23 AM
Mike Holmen
Yes mine is straight pipe to mufflers in the rear. No drone. Stock LS LQ9 with rev limit to 6000 rpm. It gets loud once I press the throttle to the floor.
Old Dec 10, 2018 | 01:17 PM
vader86's Avatar
vader86
I took the 3" off my 398 and had them step down from 3" collectors to 2.75 all the way, mandrel bent. That did make a noticeable difference, but the drone is bad at part-throttle cruise. I think an X or H is the only way to reduce further.
Old Dec 10, 2018 | 06:35 PM
Gibbles's Avatar
Gibbles
I have two xpipes, it helped with the drone quite a bit.
my exhaust is 3in, brand of the entire system w/headers is melrose, then flow master 40's for the mufflers...
the xpipes give it a bit of an exotic exhaust note.
Old Dec 10, 2018 | 07:43 PM
RetroGuy's Avatar
RetroGuy
I have the following Magnaflow internal X-pipe resonator/muffler: #12568. It has dual 2.5" inlet/outlets. They also make a 3" inlet/outlet same design. Also see their "Accessories" heading on the site for true X-pipes: www.magnaflow.com
To 3" x pipe options
Old Dec 13, 2018 | 08:20 AM
littleredcorvette88
What mufflers are you running?
Thanks!
Old Dec 13, 2018 | 08:21 AM
littleredcorvette88
Any mufflers or just straight pipe to tip?
Old Dec 13, 2018 | 08:23 AM
littleredcorvette88
Awesome! Where is the 2nd x pipe located? Does it still drone at all at highway cruise speeds or has than been wiped out with the 2 x pipes? Is the motor built? Wondering if that would rob any hp running a double x?
