variable length runner intake on C4. Anyone do it?
1) According to graph, at 3200rpm, torque difference is more like 25 ft lbs.
2) My 85 L98 had often been quoted as 340-350 ft lb TQ, and I incorrectly thought LT1's torque at same RPM was around 260-270 ft lbs. That's how I came up with 80 ft lbs. Not sure why I thought 270ft lbs, I was clearly wrong. Maybe I was getting confused with 84 TBI numbers? But 84 quotes as 290 ft lbs peak. Or maybe I got confused with other high flow intakes' like stealth/mini rams that torque drops off signifcantly at under 3200rpm. But still that's closer to 40-50ft lbs.
I dig your idea though. If you could have that ~3-3500 RPM tq "swell" that the TPI provides, then switch to a mid length runner at ~35-3700....so you could pull onward to ~6k, effectively, that would be a nice engine.
