double roller - cam retainer bolt interference - LT1
Old Jan 8, 2019 | 05:05 PM
jmgtp's Avatar
jmgtp
Default double roller - cam retainer bolt interference - LT1
Collecting parts for a cam swap - pretty much everything but the cam which I’ll buy at time of swap though have a good idea what I want already.
Already run a Meziere electric WP, have collected a vented Opti and a 95 timing cover. Plan is to go double roller. I was about to buy a Cloyes 9-3145 as it seems some have used it with success but also found in my research that it may interfere with the 2 bolts for the cam retainer. Is that true? 1994 should that matter.
Old Jan 8, 2019 | 07:15 PM
STL94LT1's Avatar
STL94LT1
I've been running the Cloyes 9-3145 in my 1994 LT1 for 10+ years without issue.
FYI: Some have had to clearance the inside of the timing cover to make it work.
Old Jan 9, 2019 | 07:56 AM
jmgtp's Avatar
jmgtp
Sounds good, knew some have to clearance the cover but was hoping the cam retainer bolts wouldn’t need to be filed down as well
Old Jan 9, 2019 | 11:11 AM
rklessdriver's Avatar
rklessdriver
The stock button head Torx bolts that secure the thrust plate to the block will be fine. I've never had them hit the back of a cam sprocket and I've built a ton of these engines.
Will
Old Jan 9, 2019 | 03:45 PM
jmgtp's Avatar
jmgtp
In my research I had come across this thread which is much of where my question came from. That said, seems like many LT1s running this set without issue.
old thread:
https://www.corvetteforum.com/forums...onversion.html
To double roller - cam retainer bolt interference - LT1
