1985 fuel pump help
Old Jan 9, 2019 | 09:43 AM
Mason123's Avatar
Mason123
Default 1985 fuel pump help
so i plan on replacing my corvettes fuel pump after school today. I’m seeing many different things on how to do it
is it as easy as disconnected the battery and pulling out the pump in the back?
or do I need to drain the fuel tank or whatever blah blah blah complicated stuff ? Thanks
Old Jan 9, 2019 | 01:44 PM
MrBigDee's Avatar
MrBigDee
I just upgrade my fuel pump to Aeromotive. You need new gasket.
I also cleaned than tank of dirt.
Old Jan 9, 2019 | 02:19 PM
playsdixie's Avatar
playsdixie
I think summit has a kit with gasket/new bolts, all stainless....I used it the last time I put one in my 85....the new bolts are much better....it's not a hard job, but on a 85, if i'm going in there, i'm changing the sending unit too...new versions are all stainless and really hold up....you may need a new rubber "boot" too.....it's hard to get the old one off if it's crusty......have fun.....
Old Jan 10, 2019 | 02:47 AM
jseremba's Avatar
jseremba
Like they said. It is a pretty easy job. I have done three 84, 89 and 85. Enjoy
Old Jan 10, 2019 | 03:00 PM
MrBigDee's Avatar
MrBigDee
I used for safety stainless steel T-bolt clamp
I also emptied the tank and clean it
To 1985 fuel pump help
