Rough Idle in Park
Old Jan 10, 2019 | 10:52 AM
temcgregor's Avatar
temcgregor
C4 of Year Finalist (appearance mods) 2019
Default Rough Idle in Park
I have a 1995 Stock LT1. The cars acceleration as normal seems to idle fine in drive but when in park idles rough and almost has a miss and the exhaust smell seems different. If you put you hand on the IAC it seems to chatter like its cyclicing. any idea?
Old Jan 10, 2019 | 11:07 PM
aklim's Avatar
aklim
Exhaust smells different from what? It is idling so it probably is different. Did you scan it for IAC counts?
Old Jan 14, 2019 | 01:19 PM
temcgregor's Avatar
temcgregor
Changed the IAC and TOS rough idle seems better but Needle is pegged at 1000 RPM idle in park.
Old Jan 14, 2019 | 03:09 PM
aklim's Avatar
aklim
If you are going to throw parts at it, might as well do coolant temp sensor and all new air hoses.
Old Jan 14, 2019 | 03:33 PM
temcgregor's Avatar
temcgregor
well listen the TSP was broken in 2 pieces and the IAC would chatter the rough idle is fixed just now high so really throwing parts at it. thanks for the help
Old Jan 14, 2019 | 04:40 PM
aklim's Avatar
aklim
Did you get the scanned values for CTS, IAC counts, TPS voltage and command idle? Is the timing spot on?
Old Jan 15, 2019 | 10:46 AM
temcgregor's Avatar
temcgregor
I haven't got my scanner yet buy the feel of the idle it more like a miss. and now is below a grand. its starting to make me lean to ignition.
Old Jan 17, 2019 | 02:22 PM
temcgregor's Avatar
temcgregor
Well went out to drive it to work today and it would crank but not fire. then when I stopped cranking it would sputter like it was trying to start. FUEL ?
To Rough Idle in Park
