Temperature sensor
Old Oct 31, 2002 | 04:05 PM
hngacurv's Avatar
hngacurv
Default Temperature sensor
Can someone tell me where the interior temperature sensor is located. My heater is working and blowing out of the right vents, but regardless of what the temperature is set on it just blows as hot as it can. I've tried pulling the codes out of it, but when I press the fan buttons all I get is 00. If I press the auto button from here I get nothing.
Old Oct 31, 2002 | 04:12 PM
tdock's Avatar
tdock
Default Re: Temperature sensor (castivers)
It could be the heater door stuck in the heat position, and it won't swing back to the AC position.
Old Oct 31, 2002 | 04:19 PM
JonM's Avatar
JonM
I am not positive...but I think its over your head, behind the little loovers.
Old Oct 31, 2002 | 04:20 PM
scorp508's Avatar
scorp508
:yesnod:
Old Oct 31, 2002 | 06:36 PM
hngacurv's Avatar
hngacurv
Default Re: (scorp508)
After doing a ton of reading through the archives I'm going to take a look at my controller resistors and then move on to the temp sensor. Thanks for the info guys.
To Temperature sensor
