I do know these facts.
The car is designed so that the fuel pump will run for two seconds after the key is turned on.
Once the car is running oil pressure goes up, over 5 psi and the car continues to run.
If the oil pressure goes below 5 psi the car shuts down.
In 1984 the minimum pressure was 10 psi.
And the link you sent me seems to support me. The C4 , 1985 until ?, Corvette requires 4 psi of oil pressure to run the fuel pump.
I have an 84 also. If the fuel pressure sender is disconnected, the car still runs. Look at the fsm of an 84 Vette (I have 2). There is nothing that shuts the fuel pump off if the fuel pressure drops. The fuel pump relay is energized when the ignition is on and the motor running. The ecm has no clue what the fuel pressure is. Also, I never sent you a link. You need to do some homework before spouting off.
Perhaps you should read this article on engine start sequence published by Grumpy's Performance. Note the third paragraph regarding Initial Crank Action.
That's an interesting read. If one just looks at diagrams, most of us conclude that the Oil pressure switch is a backup to the ECM without taking into consideration what the ECM is programmed to do. I don't really know why we think that way other than why would GM design electronic engine control only to rely on an oil pressure switch as the "Primary" means of powering the fuel pump. It seems more logical they would have designed it as the backup. In reading that article, assuming it is correct in how the ECM is programmed, the engine shouldn't start without 4PSI of oil pressure. This seems to be because the ECM won't power the fuel pump relay AND it will not enable the injector drivers AND the oil pressure switch is not closed (so the fuel pump won't run either)
If you look closely at the diagram for the ECM it says Fuel Pump Control (During Start Only). This tells me that once you release the key from the start position and let it go to the run position the ECM circuit opens and the Oil Pressure Switch closes to keep power to the Fuel Pump while the engine is running (as long as there is oil pressure)
cdm747 ,.
If I seemed rude to you in my reply. It was unintentional. I did think that your post was to the others and not to me. Sorry for an misunderstanding.
My 1984 would read the oil pressure as 9 psi and shut off. Now I had a new fuel pump and relay in the car. So I believed everything was operating as it should. I eventually bought fittings and put a mechanical gauge to test the oil pressure. Which at idle was close to 20 psi. But, the dash read 10/12. If it went to 9 the car would stall. I did purchase a new oil pressure sender. It still read low. So that is what happened.
Not sure what you are looking at. B2 is an input from the fuel pump to the ECM. There is no oil pump on the diagram I uploaded.
At s107 there are 4 lines. 1 is to the fuse then to the pump. 3 other points on the junction. 1 from the oil pressure sensor and 1 from the fuel pump relay. What is the 3rd from?
In regards to your previous question the other wire on S107 goes to the Mass Air Flow Sensor.
I have not tried disconnecting the wire from the oil pressure switch on mine. Just stating what the diagram shows.
At 1145, I tried it. Car ran with it disconnected in mid stride. Turned it off and car started and ran just fine with it still disconnected.
My thought is that B2 gives it the power as does the oil pump. There is also a 3rd option for a prime only, hence the 2 second pump run when you turn it on
How long did you leave it disconnected. I would think it would run for a while until the fuel pressure went down to zero and the fuel in the lies ran out. I am sure you have a lot more experience with this than me, i am just looking at the schematic and how I Interpret it. Hard for me to test anything as my car was just painted and is still being worked on.
cdm747 ,.
It is not a myth. My friend brought the car to chevy. They changed the oil pressure switch and the car stopped stalling. Like I said my 84 stalled when the pressure said 9 psi. Think what you want.
