HYPERTECH coil kit in!
Nov 2, 2002 | 04:15 PM
I put teh coil kit in last night and went for a drive
I was worried they'd ship it UPS and it wouldn't be here by next week, frmo RENO, but It came fED-ex and was here next day :lol:
Threw a new plug in #7 too, which stay unfouled for almost 40 miles.
Overall the car is a lot smoother.
SOTP increase? Maybe... but the old cap/coil/rotor was the cheapest crap I could buy.
Nov 2, 2002 | 04:23 PM
Glad to hear it.
Too bad you couldn't have waited ;) My stock distributor is coming out, and I'll prolly sell it(Holley module, hypertech cap-coil etc).
Nov 2, 2002 | 04:27 PM
Re: HYPERTECH coil kit in! (JD 90 383)
Oh yeah, where can I get one of those white clips for the battery line? Mine broke, and it's kind of "hanging' in there right now..
Nov 2, 2002 | 04:34 PM
Re: HYPERTECH coil kit in! (Kale)
Nov 2, 2002 | 04:37 PM
Re: HYPERTECH coil kit in! (TIMSPEED)
Thanks buddy!!!
Also last night, I took off to go in to the garage and the car felt like i ran over something and have to give it a little more throttle.
my friend said from the outside it was like a KWUMP kind of noise
:confused:
Nov 2, 2002 | 07:06 PM
Cruise-In II Veteran
You might want to pull the dist cap and put a little Lock Tite on those two nulon screws that hold the rotor.
I've had no problem with the Vette but one worked loose in the IROC.
Also, try a set of AC Delco plugs with cut back ground electrodes for the HP gain; with the HyperTech setup gap the plugs to .045" too.
Did you also do a set of low resistance spiral-would wires too?
Nov 2, 2002 | 07:25 PM
Ill be interested in the Holley Module and Hypertech cap/rotor/coil. Let me know and I can help and fund your upgrade :).
Quote:
Glad to hear it.
Nov 2, 2002 | 08:18 PM
Re: HYPERTECH coil kit in! (VetteNoob)
I'm using MSD 8.5 wires, ill regap the plugs.. sometime
hehe
Nov 2, 2002 | 08:32 PM
MSD's
Good wires.
:yesnod:
Nov 3, 2002 | 04:55 PM
Re: HYPERTECH coil kit in! (65Z01)
I second that!
Nov 3, 2002 | 05:08 PM
OR you can do what I did temporarily. Run a stock GM rotor with steel screws. . . and loctite them. That sucker should go NOWHERE with that done. :yesnod:
