Break lights
Old Mar 31, 2019 | 09:48 PM
84lover's Avatar
84lover
Default Break lights
All of my lights work except breaks. I pulled the switch and messed with it nothing. I took the switch apart and it is so simple I don't know how it could be defective. I cleaned up the contacts and observed how it works. I still don't have break lights.
Can someone tell me what the other switched mounted in the same place is for.
Old Mar 31, 2019 | 09:50 PM
C6_Racer_X's Avatar
C6_Racer_X
If you have cruise control, the second switch is for that.
Did you check for power at the switch?
If you jumper the connector (with it disconnected from the switch), do the brake lights work?
Old Mar 31, 2019 | 10:24 PM
jv9999's Avatar
jv9999
Keep in mind that the brake light circuit also goes through the turn signal switch.
Old Apr 1, 2019 | 12:43 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
If the Hazards don't work either check the Stop/Hazard fuse.
Those lights should work even with all other lights and ign. Off.
Old Apr 2, 2019 | 10:59 PM
84lover's Avatar
84lover
they dont work with a jumper
Old Apr 2, 2019 | 11:00 PM
84lover's Avatar
84lover
turn signals work
84lover's Avatar
84lover
hazard lights work
Old Apr 3, 2019 | 11:42 AM
C6_Racer_X's Avatar
C6_Racer_X
If hazard lights and turn signals work, then it's definitely the switch at the brake pedal or the wiring to that switch. Jumpering the switch didn't light the brake lights? Are you sure you're on the right switch? Maybe try jumper on the other switch.
Old Apr 21, 2019 | 02:01 AM
84lover's Avatar
84lover
I took the switch apart and cleaned it up and it works perfectly
To Break lights
