TPI to EFI
Curious as to why?
Unless you are going with a cam and better heads you probably wont even need a tune. I ran my 85 with TPIS Headers, HF cat, Magnaflow catback, Cut air lid and my K&N filter on the stock tune. Ran great and I didn't experience any ill effects. I went with a custom tune when I swapped in the ZZ4 but even with it, Edelbrock ported base, SLP ported runners, ported plenum and 52mm TB the stock computer did fine. I probably could have gained a few more HP and MPH by a custom set-up but not near the cost.
Have a blower/turbo/nitrous, or a stripped car for the track? It'll be the best mod for the entire car.
Then you consider the EBL setup. Its what, $450? MS3x with a generic harness that you splice into yours is $800.
The EBL AFAIK also doesn't offer closed loop via wideband o2, just narrowband. The wideband is only used by WUD on your laptop.
Nor does it give you different injector strategies, or work with different ignition triggers (24x, 58x, 36-1, etc).
It doesn't have any I/O beyond stock, or allow for custom triggers or functionality. Mainly because it's 30 year old electronics and software.
You're running a stock GM ECU with modified GM software that uses the expansion card.
For stock cars though it's a good fit and very popular. But it's not comparable to a good aftermarket standalone.
Rob is a very very smart guy, but I can't wrap my head around why he didn't just start from scratch and build a purpose-built ECU. Utilizing the factory p3 and p4 ECM hardware and software put serious limitations on the project.
Heck, even the Arduino based ECU's now are more powerful and feature packed and cheaper. A Microsquirt is $314 and has waaaaay more functionality than a GM ECU / EBL combo, and cheaper.
-- Joe
The Sniper is a good system, and you can modify your HEI distributor to work with it to provide full control to replace the factory '165 or '727 ECM.
You can also use the Holley HP software on the laptop to tune it, and ditch the handheld unit. I've considered using Sniper on boats, but I'm more of a fan of Megasquirt products.
-- Joe
-- Joe
And yes, Rob is the man. I've picked his brain a few times and he also isn't too far away from me if I wanted to do it in person. He actually got me my ham board installed lol.
https://www.corvetteforum.com/forums...olley-ecm.html
The first is detailed EBL swap.
The second is Holley.
I just finished my EBL in my 85. I'm very satisfied. my set up: 24lbs Bosch III, OBX headers. I sent my intake (plenum and base intake) to port match AS&M runners (1.6").
In the future I'm going to replace the cam and heads to something mild. don't know which yet.
P.s:
There is another option:
https://www.fuelairspark.com/ez-efi-...-fit-type.html
