C4 Corvette OBD code 44
Old May 23, 2019 | 10:50 PM
everettk's Avatar
everettk
1st Gear
Default C4 Corvette OBD code 44
Hey everyone - I'm brand new on here, even thought I have had my 1985 Corvette for 23 years. I recently started driving it again, and now I am getting the service engine soon light coming on after about 20 minutes of driving. I did the paper clip test, and I am getting an OBD code of 44 consistently. I've been doing some reading, should I replace the mass airflow sensor, or should I try something else? Car is running great, and usually if I keep going and give her some gas, the warning light turns off eventually. Any ideas? Thanks!
Old May 24, 2019 | 02:58 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
You might check fuel pressure both at idle and when revved up a bit.
