replacing battery tip
Old May 30, 2019 | 05:35 PM
Steener's Avatar
Steener
Default replacing battery tip
Just swapped out the battery on my 95 for the first time today. Guided by a helpful youtube video:
For those who've never done it, I would add one tip: If you can -- I'm not sure if the cable is long enough to provide much leeway -- attach the positive lead before you get the battery all the way in and clamped down. I had a bugger of a time getting my fingers or a quarter-inch ratchet on it. I ended up using an 8mm open end wrench, and even then tricky to get the bolt started.
Old May 30, 2019 | 08:08 PM
hcbph's Avatar
hcbph
Great little tool that makes connecting and disconnecting battery cables a lot easier: https://www.harborfreight.com/5-16-i...nch-97261.html
You can get it at most any auto parts store along with HF.
Old May 30, 2019 | 10:53 PM
belairbrian's Avatar
belairbrian
I have a slightly different version. It's 5/16 on one side and 10mm (for imports) on the other
Old May 31, 2019 | 06:49 AM
Steener's Avatar
Steener
Sure - now you tell me.
I may not need it for another three or four years (I hope), but I'm definitely getting me one of those babies.
To replacing battery tip
