Throttle cutting out
Old Jun 4, 2019 | 08:34 AM
CFun's Avatar
CFun
6th Gear
Default Throttle cutting out
I have a 95’ base Vette. It seems to run fine normally. The other day I pulled onto the highway and punched it. Nothing happened. The engine didn’t rev, just nothing. I had to let up on the gas and a second later it finally started moving. The engine just cut off. I had the traction control button off. Is that some kind of rev limiter? It ran fine after that.
Old Jun 4, 2019 | 09:16 AM
Kevova's Avatar
Kevova
Fuel level? Codes? Low fuel pressure, TPS, or MAF come to mind.
Old Jun 4, 2019 | 09:29 AM
CFun's Avatar
CFun
6th Gear
Fuel was 3/4. No codes. Great fuel pressure. Didn’t check anything else yet.
To Throttle cutting out
