LED headlights - 93 C4
Old Jun 8, 2019 | 10:19 PM
dizwiz24's Avatar
dizwiz24
Default LED headlights - 93 C4
I know this has been beaten to death - but the technology is emerging and I need to get some recommendations.
I dont like the ‘spider eye’ look of some of the LED headlights. It looks ricey to me, but I will put up with it if there is a benefit in down road lighting
I like the look of the GE nighthawk style LED headlamps. But there are lower priced options.
whats everyone recommend ?
I have my current headlights wired with relays and heavy 10 gauge wire / daniel stern bosch e spec 100/130w bulbs. So it provides amazing lighting but a heavy amp draw
looking for similar lighting performance w/o the amp draw
Old Jun 10, 2019 | 11:56 AM
3D-Aircrew's Avatar
3D-Aircrew
I installed these instead of spending the same amount for 1 seal beam headlight:
https://www.ebay.com/itm/7-X6-LED-HI...97.m4902.l9144
I'm happy with them and they are very bright.
Old Jun 10, 2019 | 03:06 PM
aklim's Avatar
aklim
https://www.corvetteforum.com/forums...s-in-85-a.html
Old Jun 11, 2019 | 04:05 PM
dizwiz24's Avatar
dizwiz24
What about replaceable H4 LED bulbs into my ‘tried and true’ bosch e spec reflectors?
prob save some money?? Vs the ones with led’s built into the reflectors
Old Jun 11, 2019 | 04:09 PM
aklim's Avatar
aklim
Is that significantly better than the "tried and true" stock bulb? You are still running incandescent yellow lights. Not sure about you but while the bulbs might not be brighter, it definitely does make it easier with a whiter light than yellow, at least to me.
Old Jun 12, 2019 | 04:43 PM
jsinga's Avatar
jsinga
I did the Daniel Sterns upgrade to my 87 with Ciebe lamps. As of now I don't think anything will get you better lighting. Those 100/130w bulbs are like the sun. I know they draw some current. I check mine on low beam once; 18amps.
Old Jun 12, 2019 | 06:18 PM
aklim's Avatar
aklim
Yes and they might also make the cop wonder if you're driving around with the brights on and stop you for a chat. That was my problem with it while I was driving my other car.
To LED headlights - 93 C4
