Suspension information
Old Jun 24, 2019 | 01:59 PM
drcook's Avatar
drcook
Finalist 2020 C4 of the Year - Modified
C'est un ressort de la société Eibach. Les chiffres sont probablement la notation. Voici le site web. La prochaine est le site web mondial, il est un lieu en Allemagne.
That is a spring from the Eibach company. The numbers are probably the rating. Here is the website. Next is the global website, there is a place in Germany.
https://eibach.com/us/
https://eibach.com/us/p-14-eibach-globally.html
Old Jun 24, 2019 | 02:08 PM
fred of france's Avatar
fred of france
Thank's for the links , i've also try !
I 've not find information about these number '22/95'
Old Jun 24, 2019 | 03:24 PM
drcook's Avatar
drcook
Je me demande si cela signifie 22e semaine de 1995
I wonder if that means 22nd week of 1995
Old Jun 24, 2019 | 03:45 PM
fred of france
I thought about it too
I think that by dismantling it I would find these characteristics ????
Old Jun 24, 2019 | 08:37 PM
ChumpVette's Avatar
ChumpVette
Spring rates are usually etched on the top or bottom of the spring on the portion that is flat. Hyperco has started embossing the rating on the coil portion of the spring.
Old Jun 25, 2019 | 02:53 PM
fred of france
i 've a response of Eibach : 22/95 is the date of production 1995 the 22th week
For the rate , it's on the seat of the spring as they say
Witch rate is the better to have a confortable car ,according to you ?? i 've read about 450lbs for the front is good
Old Jun 25, 2019 | 03:32 PM
Hot Rod Roy's Avatar
Hot Rod Roy
You should know the rate you now have, to best answer that question. The rate is sometimes marked by a color code (paint mark) which you may be able to see without removing the spring from the shock. What does Eibach recommend for your car? So much of your question is personal taste!
Old Jun 25, 2019 | 04:18 PM
fred of france
Eibach don't recommend me , so i don't ask her the question
I don't see the Corvette Convertible 1992 in her shop ????
Old Jun 26, 2019 | 03:16 PM
fred of france
I am curious to know what type of spring is installed , inscribed on the end ?
Does this rate also correspond to the comfort of the vehicle ?? that whould i search
For the Front of the car 400 / 450 Lbs /inch seems a good value ??
Old Jun 26, 2019 | 03:50 PM
Hot Rod Roy
The springs you now have in the car may already be 400-450 pounds per inch. You won't know unless you can see the color code, or you may need to remove the springs from the shock absorbers (dampers). I am sure you do not want to purchase new 400 pound springs, and then discover that you already have that same rate in your car!
Yes, a lower rate spring will soften the ride of the car, but will degrade the cornering & handling characteristics of the car.
Old Jun 26, 2019 | 04:18 PM
fred of france
Exactly ,, i woulld be fixed if i remove the spring and see it's rate
