93 a/c not working
Old Jul 26, 2019 | 03:57 PM
WLRDLR's Avatar
WLRDLR
Default 93 a/c not working
Hello, my 93 was sitting for 12 yrs. I just replaced the accumulator & was having my friend who is a hvac co. owner charge it w/r12. The clutch cycled a couple of times but won,t cycle anymore. He hot wired the clutch & the compressor works & cools.The plug in at the compressor has no voltage. He checked the switch that is located at the top line going into the heater box & said it,s o/k. The system is full of freon. The control on the dash seems to operate sporadically. If I push the off button it will not turn off. Do you think that heater/a/c control is bad? He suggested putting a toggle switch under the hood to run the clutch when I need to drive it. Do you see any problem w/that until I can figure out what,s wrong w/the system? THANKS
