Need help
Old Aug 4, 2019 | 02:29 PM
Anthony Cebada's Avatar
Anthony Cebada
Cruising
Default Need help
I am a new corvette owner & im having problems with the car overheating ...I have changed everything from the radiator cap to the head gasket ...the whole cooling system is brand. New ...I need someone to help me set the timing ...I’m in Decatur Georgia off river road ...I’m almost ready to give up ...somebody please help
Old Aug 4, 2019 | 03:05 PM
s carter's Avatar
s carter
What year? How Hot? Are the Fans kicking on? Have you inspected the area in front of Radiator for Debris.
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
Welcome to the C4 group! What year is your C4?
What is it that makes you feel the car is over heating? Is it boiling over or ... do you feel that the temp on the analog gauge is too high?
Old Aug 4, 2019 | 03:50 PM
Anthony Cebada
Cruising
Default Need help
My c4 is a 89 ...I’ve changed the radiator...the water pump...the head gasket ....milled the heads ....new hoses ...cooling temp sensor ...radiator cap ...thermostat ...car is still running in the 240 to 250 range after only driving 6 miles ...my contact info is #4704530528 ....please help
Old Aug 4, 2019 | 03:52 PM
Anthony Cebada
Cruising
Default Need help
I have spent $2400 on labor & parts in the past month on this car...& it’s still running hot ...I’m at a loss now ...it’s kickin my ***
Old Aug 4, 2019 | 04:31 PM
s carter's Avatar
s carter
Has the car been overheating since you have owned ( it's new car for you) do you know if the Engine has been bored out to something like a 383.
When engine is running do see coolant flowing through Radiator? I almost wonder if the Intake gaskets are on backwards with the block off plates at the front right now.
Old Aug 4, 2019 | 05:43 PM
jseremba's Avatar
jseremba
Have you changed the temperature of the fan switch. Or you could have one of the PROM tuners , Scott Hansen for instance, send you a PROM so with the fans set to 210 degrees. I have a 180 thermostat in my car and the fan comes on a 210. Car has not overheated. The other thing you may try is an external oil cooler.
Old Aug 5, 2019 | 04:29 PM
vader86's Avatar
vader86
https://www.corvetteforum.com/forums...erheating.html
https://www.corvetteforum.com/forums...-the-heat.html
Have you addressed any of the questions posed to you in the other two threads you started?
Old Aug 7, 2019 | 04:21 PM
DGXR's Avatar
DGXR
Here is another good read: https://www.corvetteforum.com/forums...peratures.html
To Need help
