ASR Module
Old Sep 19, 2019 | 02:18 AM
rusty76's Avatar
rusty76
Default ASR Module
I have a 1993 LT1 coupe with a 6 speed.
Is there a vacuum line coming out the rear of the module, near the hose from the AIR system? I have a nipple on mine that has no hose attached to it. I've been trying to find a picture or diagram of the connections to that module without success so far.
I realize there is a vacuum line that comes in on the front of the module. I'm just trying to confirm whether or not I'm missing a rear mounted vacuum line?
Thanks.
Randy
Old Sep 19, 2019 | 07:54 AM
Kevova's Avatar
Kevova
ASR does not use vacuum. AIR management valve and vacuum hoses related to cruise control are in that area. Vacuum hoses tend to split/rot near battery.
Old Sep 20, 2019 | 10:28 AM
pcolt94's Avatar
pcolt94
The AIR system pump is located all the way front left by the horn and is to control emissions.
The ASR unit in about a foot forward of the ECM in the middle on a bracket with throttle cables running to it. It's all mechanical and electrical.
The cruise servo is over the battery. It has 2 vacuum lines connected to it on the bottom. One on the lines is vacuum from the engine. That line connects to a T junction near the wheel well. The other vacuum line goes back thru the fire wall and connects to the brake and clutch pedal for cruise disengagement.
To ASR Module
