Cam Rec for FIRST build
Philosphy of use: second car, want a fun, fast street car. Not necessarily after some crazy sounding cam, just want to make good power and work well. If i could get close to or above the early ZR1 in terms of crank HP i would be happy.
350 CI
FIRST intake
AFR 180cc heads, or Profiler 185 (similar flow) - plan to get them milled to 58cc (maybe less to bump compression, unless thats a waste of time) combustion chamber regardless of which one i go for
Hedman 68448 long tubes (i assume 1-5/8 is more ideal for a 350 than a set of 1-3/4)
Also, I have a bead on an unused set of these roller rockers for a good price. are these worth buying? https://www.summitracing.com/parts/cca-17001-16
dual 2.5 exhaust with h pipe (i prefer the sound over x pipe) to corsa mufflers
also considering thinner gaskets to help bump compression. What is the thinnest i could go before i run into quench issues? i have seen some people go with fel pro 1094 which has compressed thickness of .015
Cams I am considering:
LT4 hotcam. works, but from what i understand the rpm range isnt ideal for l98 (melling also makes one with near identical specs for significantly less than the GM cam)
https://www.summitracing.com/parts/c...make/chevrolet - states high performance street for modified TPI, sounds promising
https://www.summitracing.com/parts/l...make/chevrolet
I may or may not replace the factory lifters which is why i included the cam/lifter combos , however i am leaning toward doing so as there are 92k on the clock.
For the tune I will go with ed wright, or FasterProms does mail order tunes however I am local to them so that may help. Also the owner's dad apparently helped to design the miniram so he is familiar with the l98.
Dont like cams with too aggressive a ramp it just shortens the life, not worth any gain you probably wouldnt feel anyways. Just an opinion..
Would choose the afrs over the profilers also to each thier own. Prefer US made stuff when you can get it.
Also, it is a really good idea to change the lifters when installing a new cam so they can wear in together. The GM Performance LS7 lifters are drop in and used to be pretty cheap (12499225). They are a little bit taller, but you will need to measure for new pushrods anyway after changing heads and getting them milled.
Or should I look for something with lower duration at 50
https://www.summitracing.com/parts/h...make/chevrolet
Or this one is you need a step on the nose of the cam for the retainer plate. Not sure what year you have.
Get a hold of him and tell him what you are doing. He can help you
Ive only ordered 1 custom that worked the rest were a big mistake. Most off shelf stuff is proven
